rovopio
- Jan 18, 2014
I'm not sure for that one, but I would guess it reduces the original recording volume and takes away some of the detail if you try to play it at the original volume, but if you play it at the volume you have it set for on the computer it should sound just fine. Then again, I don't know much about what I'm talking about now, so this is all speculative.
Yeah, when I watch youtube, I don't even use my Magni or Modi, I just plug some earbuds into the headphone output. For movies though, I like to get the full experience, so I dim the lights, crank up the volume, and power on my Magni/Modi
speculation is fine really!
let me reiterate again...
by "if you try to play it at original volume" you meant if i set the windows OS SPDIF volume at 30, and then i set the magni at 12 or 1 o'clock, that's artificially amplifying 30% PC signal to half of magni full power....
while what im using now, SPDIF at 25 and modi at 8 o'clock... that's just forwarding similar level of signal...
is that what you mean?
