Erukian
- Mar 31, 2004
Do you think that maybe it's your brain that's adjusting to the sound?
Here's my two cents. Initially when you hook up the amp your ears are hearing a different sound than what you're used to. Then after an arbitrary number of hours, your brain figures out how to ignore the information it doesn't want and you can tune into the information that was missing on your old gear.
Think of a fan turned on in a room while you're watching TV, after a bit you mostly ignore it because your brain is focused on what it wants to hear, the dialogue of what you're watching. I suspect our brains do the same discarding to super revealing dacs/amps in a similar way and after time, we just hear the good stuff.
My Mjolnir definitely burned in after 100+ hours. The HD800s were pretty unlistenable to me up until that point. I'd think an LCD owner might not notice the burnin as much since it's a pretty synergistic combo from the get go. For the HD800 though, the treble finally became acceptable, the bass came around, and the entire presentation was less aggressive and more defined all the way around. This ss amp changed more than any other I've owned. I also found that different powercords make a difference with the Mjolnir (and Bifrost) as well. YMMV.
-Daniel
