crazychile
- Feb 13, 2003
I have a Sennheiser HD700. Which is a better amp for singe ended operation, the Lyr 2 or the Mjolnir 2? I understand that the Mjolnir 2 is a better choice for future upgrade to balanced. I like the Lyr 2 better for its smaller footprint. Does the Lyr 2 sound better because it was designed to be single ended?
While some have reported that the single-ended outputs of Ragnarok (and therefore Mjolnir 2 using the same topology) are not as good as the balanced, I can say that both the HD700 and the HD800 sound great single-ended from the Mjolnir 2 (while waiting on my balanced cable). While the balanced does sound better, I haven't found the single-ended to be quite as lacking as some reports have indicated. I can't compare it directly to the Lyr 2, though, as I haven't heard it.
Yeah, I don't get why people are so shocked that Balanced is noticeably better than SE. If it's done properly, it SHOULD be better. That's kind of the point of it all.
