TsKen
- Jan 13, 2013
What other headphones would be a good pair with the Mjolnir 2 + Gumby combo besides the HD 800/650?
Yeah, the question is better posed: "What headphones wouldn't be a good pair," and then the list is electrostatic, and maybe HE-6 and K1000 for power reasons, though even then the pairing is an acceptable entry pairing. Everything Audeze, Sennheiser, AKG, Grado, Hifiman, Mr Speakers...haven't tried Abyss but I'm sure it could drive them at least as well as HE-6.
Good to know that every headphone pairs well with it
every amp i've used so far has been picky about pairing with certain headphones.
Any one using a Mjolnir 2 with Audeze LCD-XC and/or Meze classic 99? Looking for a new amp only, suggestions welcome.
Yes Have both and driven them to their best ( i think ) with the Mjolnir 2. However my Auralic Taurus 2 with balanced Grado PS1000e and flat pads are a better SQ by quite a long way if you like rock music.So if thats what you want think about it.
Just waiting for a balanced cable for my Gen2 Beyer T1's to compare the amps. Mj2 with Russian valves by the way. Both systems fed balanced .
Only tried Meze 99 with SE output and new design Meze pads meze stock cable.
LCD-XC with balanced silver cables. Hope this helps ?? Mj2 with russian valves a great system.
Auralic needs an expensive front end for its best otherwise can be a bit forward.
thanks for the advice the Auralic Taurus 2 looks immaculately constructed, I'll give it an audition.
I've used my Meze 99 on MJ2's balanced and it sounds much better than the SE. So far the MJ2 with ifi NOS tubes sounds great with my collection of: Ether Flow C, HD800 SD, and Meze 99 all in balanced only.
Here's my Meze99 balanced: http://www.head-fi.org/t/794593/meze-99-classics-discussion-impressions-thread/780#post_12782636
Hey guys,
since I don't want to get into the whole tube rolling thing, I wonder if the Mjolnir 2 will sound better than Asgard/Jotunheim with LISST only?
Initially I wanted to get the Bimby/Jotunheim combo, but now I consider Gumby/MJ2 with LISST. I may get the tubes as well, just for comparison.
Right now, I have a K702, will get K7XX soon (also for comparison) and I am on the search for new headphones. Right now considering HD700 and Ether Flow. No classical music here and I don't like HD600/650/Elear sound.
Thanks for any advices!
I'm surprised at the seeming lack of interest in this amp. I found it to be exceptional. Responded well to tube rolling, punchy and dynamic with an air of refinement thrown in. Even with a good set of NOS tubes added, you're still under $1k.
