DarknightDK
- Sep 25, 2011
Looks like a great product at extremely attractive prices.
This is going to be very popular.
The modi is; "USB Powered, No Drivers Modi plugs into virtually any computer—Windows or Mac—and requires no drivers to deliver great sound, up to 24/96 sampling rates. It features asynchronous transfer with individual crystal oscillators for the 44.1 and 48k sampling rates, and uses the USB Audio 1.0 standard over USB 2.0, and is powered by the USB port."
Sub optimal in my opinion. PC power is flaky and dirty and better results are usually obtained by a dac that has it's own power supply. If you use this I would at least use an external powered USB hub instead of plugging it straight into a computer. That makes a night and day difference for my HRT MSII.
I was thinking about buying the O2+ODAC. Now I have to wait for comparisons. But the Schiit does look a lot better than the O2.
I was also thinking about the O2/ODAC, but I really dislike the use of all mini-jacks--the 3.5mm in/out and the mini-USB. Small jacks and connectors seem to be a lot more prone to problems--breakage, pulling out, bad connections, etc. It's great to have some choice for the reasonably-priced products.
DIY to the rescue!
DIY to the rescue!
Originally Posted by FraGGleR /img/forum/go_quote.gif
I plug my stuff into a USB3.0 port that has much more power on tap which might explain why I don't hear a difference.
One thing to consider is a USB isolator. It was recommended to me by the co-developer of the ODAC as something to consider if I was having ground loop or other problems. Many run off of external power. There are threads on them and might be better than an unregulated and unfiltered hub if true USB audiophilia is your concern.
I won't contest whether or not using a hub helped your system, just want to balance out the "night and day" differences with something a little less dramatic for people just stepping into this area.
Indeed. Audiophilia is my concern and that is why I am saving for a new DAC. A usb hub can be had for less than $20 so there is no harm in giving this a try, or other solutions, even if you are just stepping into this area.
What DACs you have in mind?
