sorry, wrong thread
My crystal ball indicate a refund is probably good idea.
So I bought a RCA 6sn7gt vt231 that finally arrived yesterday. After opening it to inspect it I could hear a little tinkling sound coming from inside the tube. After trying to inspect it through the mica coating with a bright light, I believe I saw that it is a small piece of glass. They seller did not disclose this in the auction, but he did say it was fully tested for leaks and shorts so he would have had to know it was loose in there.
My question is should I get in contact so I can return it for a refund or do you think it's safe to keep and use?
....with a Siemens logo.The last photo in the auction is not even an A-frame tube........
A loose piece of glass is not necessarily a show-stopper. It could be a spurious fragment that was left during manufacture, and then busted loose during subsequent handling. I've run across several tubes over the years with a tinkling piece of glass, and the tube(s) worked fine and sounded fine. As long as the getter flash is still bright silver, then it's not something that has broken internally and resulted in a leak. All that said, I agree with TK that if you can return for a refund (or replacement), that would be the best way to go. If not, I'd try it and see what it sounds like without worrying about it causing a problem with the amp. As glass is an insulator, there's no risk of it causing a short if it gets lodged between leads internally.
Now that I have the MJ2. I may be interested in some of those 5670’s. Let me know if you decide to sell
I totally agree. I've had tubes with a glass fragment loose inside that tested and worked totally fine.A loose piece of glass is not necessarily a show-stopper. It could be a spurious fragment that was left during manufacture, and then busted loose during subsequent handling. I've run across several tubes over the years with a tinkling piece of glass, and the tube(s) worked fine and sounded fine. As long as the getter flash is still bright silver, then it's not something that has broken internally and resulted in a leak. All that said, I agree with TK that if you can return for a refund (or replacement), that would be the best way to go. If not, I'd try it and see what it sounds like without worrying about it causing a problem with the amp. As glass is an insulator, there's no risk of it causing a short if it gets lodged between leads internally.
Thank you for the detailed answer!
If he won’t return it at least I know it’s useable. I’m more irritated that it wasn’t disclosed in the first place. If I would have know then I probably would have bought or bid on a different tune. If it was only a $15 tube then I would just keep it and not worry, but since that isn’t the case I opened up a return.
I appreciate you're not looking to sell it all separately, but if you do decide to break the pack up, I'd be interested in the Teslas.Hey tube people, check my sig, no longer own a 6922 amp.
And I would be interested in the Seven Western Electric JW 2C51's
Did you message him before opening a return? Buyers are usually more helpful when you message them before taking action via ebay/PayPal.
