Cool. Thx for your replyNope no issues. I got my Gumby feeding my speaker amp from the SE1 and my headphone amp from SE2.
Schiit Gungnir DAC
- Thread starter WarriorAnt
Mizicke5273
Been thinking about getting an Eitr for my rig and I just placed the order for it. I had been considering the idea of just getting the USB 5 upgrade done, especially since I bought my Gungnir used. But I just don't want to be without my Gungnir and I figure I could always use the Eitr with another DAC; should I decide to upgrade to a new Gumby or Yggy after USB 6 drops.
In my opinion the other inputs are way better than USB. USB sounds kind of muffled by comparison but then again I didnt use a really high end cable. I believe coaxial is still the best source as long as its rated properly. Optical revealed some high level detail in the treble and clarity and I still feel like theres a veil until I use a high end coaxial cable like the river series by AQ, etc
Mizicke5273
I ordered a Monoprice Coaxial cable a few weeks ago, to have on hand, and I also just ordered one from Ghent Audio as well. This two will be good enough for now. The Monoprice one was cheap but is 3 ft, so it is a bit longer than I should need. I don't like having excessively long cables with lots of slack, so I got the Ghent cable in a shorter length.
RCBinTN
Not in my experience. Gen5 USB blows away the optical SQ (in my Gumby).
Believe me, I was using AQ diamond optical until Gen5, but now I'm on USB and not going back!
A valid question is whether to wait for Mike's USB Gen6, which I've heard from reliable sources is exceptional ... beats Gen5.
It depends on if you want to wait, and how long - good time to start asking Mike/Jason for launch date now that Aegir is commercial.
Happy Listening!
RCB
I got my gungnir used $850 with mutibit and usb 5. No complains
RCBinTN
Please post your experience with the Gen5 USB (via Eitr) to educate this thread. Thanks.
Happy Listening!
RCB
Can you elaborate? What would you say were the upgrades you got from going from optical to USB? What USB cable are you using? I hear less digital glare with my Starlight Optical cable. It just sounds smoother without losing detail.
RCBinTN
Sure. I was using USB Gen2 that sounded OK but I had issues with reliability - music drops (source Macbook Pro direct to Gumby).
So I went to optical. Got a very stable performance. Even went to the AQ diamond optical cable at $500 trying to get the best SQ.
Then, I was able to experience the Gen5 USB, and I switched back to USB.
No more instability issues ... rock solid.
To me, the SQ is much better with Gen5 USB than even my uber-optical cable (which I do not recommend, BTW).
The Gen5 sound is more detailed and transparent, whereas the optical sounds veiled in comparison.
YMMV, thx for asking.
artur9
- Apr 25, 2015
My favorite connection on my Gumby is the BNC. But try finding something that outputs that! I'm trying a Coax->BNC adapter to see how I like it.
What USB cable are you using now? Im curious to try it again if its as you describe but I was using a cheap Belkin cable so it sounded muddy.
I think adding more parts to the signal chain would degrade quality although some people get USB to coaxial/BNC transports like I believe the Hydra X. Coaxial and BNC are virtually the same with different connectors. Just harder to find on spec coaxial cables.
artur9
- Apr 25, 2015
I'm hoping not for 2 reasons.I think adding more parts to the signal chain would degrade quality although some people get USB to coaxial/BNC transports like I believe the Hydra X. Coaxial and BNC are virtually the same with different connectors. Just harder to find on spec coaxial cables.
(a) My BNC cable is really high quality. And... attractive
(b) the BNC connector is really better than RCA. As I've said before, I wish the world had settled on BNC instead of RCA lo those many years ago.
From what I’ve read, I’ve gathered that the optical in reference is toslink, not coaxial. Which also makes a lot of sense, as it’s known to be noisyCan you elaborate? What would you say were the upgrades you got from going from optical to USB? What USB cable are you using? I hear less digital glare with my Starlight Optical cable. It just sounds smoother without losing detail.
I haven't run into this issue with it being noisy but most Optical on a consumer level is Toslink and not Coaxial. I'd be willing to try the USB input again if someone can recommend a good cable. Right now I'm looking at other options like a Nordost Purple Flare for my Node 2 Transport.
rkw
Optical = Toslink. They refer to the same thing.most Optical on a consumer level is Toslink and not Coaxial.
Coaxial refers to coaxial wired cable with RCA or BNC connectors.
Total: 12 (members: 0, guests: 12)
