Schiit Gungnir DAC
Oct 26, 2018 at 6:20 PM Post #5,417 of 7,049
Oct 29, 2018 at 2:26 PM Post #5,419 of 7,049
gold caps?
Oct 29, 2018 at 4:33 PM Post #5,421 of 7,049
Damn @Ableza -- I almost spit up my bier :)
Don't disassemble your Gumby - voids the warranty, my friends.
Just go by the serial number ... I completed my research assignment.
Enjoy the ride and your music!
RCBinTN
Oct 30, 2018 at 2:04 AM Post #5,422 of 7,049
@RCBinTN -- you forgot to drop the mic, don't take it home :.b
Oct 30, 2018 at 12:46 PM Post #5,423 of 7,049
ROLLING EDIT: Immediate first impressions upon turn on (no warm-up; vs eitr + mimby; into lyr 3 + pmx2)
  • Much punchier (bass seems to extend further)
  • Much greater air and blackground (voices, drums have such beautiful taper-off into nothingness)
  • Layering and imaging is _MUCH_ better (you can hear individual singers and instruments so much easier... it's actually almost overwhelming vs what I've experienced before)
  • Not a hint of grain at all (immediately noticeable with higher piano notes)
This exceeded my (already absurdly high) expectations. I'm impressed.
Oct 30, 2018 at 1:24 PM Post #5,424 of 7,049
Yeah, I had the same but now I'm used to it:.)
Oct 30, 2018 at 3:44 PM Post #5,425 of 7,049
Happy Listening ... enjoy your music!
Oct 30, 2018 at 5:18 PM Post #5,426 of 7,049
thev analog 2 board have gold labeled caps. the analog 1 had silver covered caps. this is what noticed.
musicguy
Nope!
Well i mean that there was a revision even at the analog 1 board.
The original was with normal caps but after a while they opted for the gold ones.
I have opened mine to install the usb 5 board and the caps are gold.
Oct 31, 2018 at 9:22 AM Post #5,427 of 7,049
Jason has written on his thread about the need to substitute PCB components at times due to supply and/or quality issues.
The caps are likely one of those components that get substituted.
Substituting similar-spec caps on an existing PCB design isn't a "change," as long as the caps perform the same as did the old caps.
Re-design of the Gumby's analog stage, now that is a "change" because the DAC will function differently.
A design change needs to first be validated (that it works) and then verified (that it can be repeated in production and is stable in use).
FYI, friends.
RCB
Nov 5, 2018 at 1:49 PM Post #5,430 of 7,049
Question for you Gungnir Multibit owners: If you were not going to leave Gungnir on all the time and actually power it off when not in use, would you still have bought it? I am considering a Gungnir Multibit, but would only be powering it on when I'd be using it. Would it be a waste to get a Gungnir Multibit then?
