johndean
- Aug 24, 2015
I use 5 Gungnirs in my active system. One of them is hooked up to a single-ended amplifier. I use the balanced outputs for that amplifier with a pair of simple XLR to RCA connector adapters. The amplifier has a volume control (input gain attenuator), but because the adapter is throwing away half the signal anyway, the inverted signal, the output levels are relatively safe for single-ended gear. I have never used converters. Soem of these convereters look like they are simply using a transformer to lower the output voltage, but then you are still going through a transformer. The balanced output stages of the Gungnir and Gungnir multibit are very good. I prefer them. If you feel the need to use the RCA single-ended outputs, by all means use them, but I feel the sound quality of using an XLR to RCA adpater is better because you are not listening to the summing circuit that is in the RCA output stage.
-TRQ
Thanks for your input . What xlr to rca adapter would you recommend . My integrated amp has only rca inputs and I would like to check out the xlr outputs of my Gungnir .
