bigro
- Dec 18, 2014
Posted this on Jason's but thought I would ask here also:
Noob question here:
Fulla II, usb,
what signal is the unit pulling from my laptop MacBook while playing iTunes or a CD in the laptop? Is it analog or digital?
I did have a few fals starts with the unit but after boiling s bowl of pasta I came back and tried again: power usb, then signal usb, then variable pre out, then opened the system preffs. Recognized the F2 instantly. I did plug and replug the cables a few times. Ok, admission of guilt I did plug the aux cable from my little Yamaha into the minni plug in the front of the unit first... 100% Googan
I am a 2ch guy just pationantly waiting for the Frea and vadar to be released. I bought the F2 unit to play with and have a little skin, I was going to type schitt, in the game.
Thanx
The Signal Is Digital from USB.The Fulla 2 is a Digital to analog Converter (DAC) and headphone amp combo. Also USB is a Digital only Bus
WHen you set the F2 up in windoze Ideally you would set the volume to Max on your PC (for the I'm Fulla Schiit control) then use the fulla 2 to control your volume. And also change the settings to accept 24/96k as it will default to 16/44.1
