benchan2
- May 20, 2017
Does D5 get hot when playing? Cause 1 thing I am very satisfy with my DX3 Pro now is that it does not get hot at all.
if i am using line out of the sabaj d5 .. does the xlr and rca plays at the same time ???
currently my basx a-100 is plugged via rca line out and id like to buy a thx 789 amp and plug it with xlr .. does the 2 amp going to play at same time ???
Can confirm this. The DAC has really great sound via XLR, better than my old Yulong DA8. Does an excellent job despite its price in my rig (Questyle CMA800R Mono Amps, HD820/800S)I still love mine ... the only thing I wouldn't recommend it for is really sensitive IEMs. I connected my triple fi custom quads, 2.5mm balanced cable to a Massdrop XLR adapter, and got some hiss. Same thing with my Tenhz P4 Pro. I suspect an impedance above 1, since I have zero hiss connecting these IEMs to my Shanling m3s.
I love this DAC/AMP with all of my full sized headphones.
Hello, I bought mine from amazon.de… fast shipping, quick response to a support question – had no problems. 370€ at the moment as B-Stock.Buyers be aware! Had a bad experience when ordering from Sabaj Store Aliexpress. D5 order was made at the end of Aug from clearance. Seller sent a tracking number and indicated that item was shipped (from UK). Turns out tracking was fake and item was never shipped. Dispute is currently in progress. Hopefully get my money back.
So where one can order D5 in EU....other store than Sabaj...? Amazon has them but Sabaj is a seller...unfortunately.
anyone has issue with the remote? I don't seem able to get mine to work.
Try pressing the A B or C then test again. I can't remember which one it is but it should work when you select the correct letter.
Edit: Its "C"![]()
Yes, C works. Thanks very much!
Had the same question for Sabaj Support and they confirmed letter "C" had to be pressed.Try pressing the A B or C then test again. I can't remember which one it is but it should work when you select the correct letter.
Edit: Its "C"![]()
I found out about the C button after a frustrating hour one evening.......
