Originally posted in Skylab's review thread -
http://www.head-fi.org/forum/thread/529311/review-ray-samuels-audio-sr-71b-balanced-portable-headphone-amp/30#post_7146829
INITIAL IMPRESSIONS SR-71B:
My SR-71b arrived on the 22nd, and I have only had time to try the HE-6 and JH13Pro balanced with the SR-71b so far. The SR-71b sounded great right out of the box, but I'm still giving it some burn-in with music into my balanced JH13Pro. After some listening with the HE-6 balanced I can say that the SR-71b is "significantly" more powerful than my balanced Protector (using TWag "Protector to 4-pin XLR" adapter).
While the Protector drives my HD600 and HE-5 LE with authority, it can only maintain "conversation level" volumes with the HE-6; but the SR-71b drives the HE-6 better than I ever hoped. I didn't believe it until I heard it for myself. And it's not just in having enough power, but the sound quality is also superb. I would have to say the treble quality is smoother than the Protector in balanced mode so far. Bass, mids and highs are all excellent and balanced in respect to each other. So, in both power and sound quality I'd say the SR-71b has an edge over the Protector, and that's with less than 24 hours on the SR-71b and over 1,000 hours on the Protector. One thing to note is that the Protector in balanced mode sounds slightly more aggressive than the SR-71b or P-51, although less so via single ended mode. While the Protector has been perfect for my balanced JH13Pro, the SR-71b is every bit as good or better with them and yet not too forward with the HE-6. (I have not swapped over my Westone IEM to the balanced TWag cable yet, as it's too early in my ownership to try anything else.) I will compare the balanced output vs SE output later.
There are several other amps that I reported on in the HE-6 threads, including the HDP, SAC KH1000, EF5, WA6 and ZDT. I haven't compared the SR-71b yet to them, but I can say that I do believe it's a better match than HDP, SAC or EF5 in terms of sonic synergy and balance because I'm enjoying the combo more. I previously felt that the SAC and HDP amps could be slightly bright with HE-6 as the volumes got higher, and the EF5 had a good balance but lacked the detail and soundstage of the other amps. I'm certain that I would pick the SR-71b over any three of those amps for my HE-6. I'm surprised that I can turn it to max volume without signs or strain or distortion like with the above desktop headphone amps. My ZDT also allows me to max out the volume with the HE-6 without any distortion, and I would not be surprised of the SR-71b can match volume levels with the ZDT, based on what I am hearing up here in my bedroom rig. The SR-71b is clearly more powerful driving the HE-6 than my WA6, although I didn't have many complaints about the sound quality at normal volumes with the WA6. The WA6 is phenomenal with the JH13Pro, and it's too early to say how the SR-71b compares, although I am not hearing anything that I would want to change or fix with the SR-71b.
As stated above, I have not had time to try any other full size phones or IEM with it yet. I am planning to order a balanced LCD-2 Silver Dragon cable in the next week or two, so I'll be able to listen like I did at RMAF with the demo SR-71b and LCD-2 - I loved that combo there. My HE-5, HE-5 LE, HD600, HD800 are already balanced with a 4-pin XLR like the HE-6, and I'll try them later on the SR-71b. Plus with my Protector adapter and my APS V3 1/8" adapter I can use all these phones on any of my amps. So that will make comparing amps easier later.
I wanted another small balanced SS amp, and I have gotten my wish. So far, just with these two phones I have no regrets about spending $614 on the SR-71b, and all my desires to repair my balanced Single Power Square Wave XL's broken PSU have evaporated.
