revolink24
- Jan 12, 2008
Quote:Quote:The Toucan is $229. Go figure...
However, they really are two different products. The SR-71B is smaller and more portable than the Toucan, has a slightly better sound, a little more power, an two volume pots that you can adjust together or independently, three gain settings instead of two and probably a few other things I am forgetting. The Toucan is probably the better value, but by no means is the SR-71B put to shame. They are different.
George, have you heard the toucan and been able to compare it to the sr71b? i've not heard direct listener comparisons of the two as folks have only heard the prototype sr71b and not too many seem to have the toucan yet. your observations may be correct but they seem speculative rather than from any real experience. this is a trend on head-fi which has the potential to lead folks to erroneous conclusions, which they sometimes get vociferous about (and sometimes in quite ugly fashion). i'm ont accusing you of this, but rather asking that you be careful when posting speculative posts, and then make sure that that's clear.
Thanks Eric.
Just to be clear, I have heard the SR71B, but I have not heard the Ibasso Toucan. My post above is largely speculative, based on what I have read in a smaller part in what I have heard. Hiflight found the Toucan can actually drive the AKG K1000s to a degree, which to my understanding is an impressive feat. I did hear the SR71B driving the HE-6s very well, and there seemed to be no deficiencies in the sound. The Toucan has 26.2 volts of swing peak to peak, and the SR-71B has about 30. I believe the ability of an amp to drive headphones is closely correlated with their peak to peak voltage, but correct me if I am wrong. I was just doing a speculation about the only two fully balanced portables out now, and one or more of my points could be wrong. Heck, someone has already stated the SR-71A doesn't have the airy and open sound and driving ability of the Toucan/Boomslang combo but has more bass impact, and this SR-71B is a lot better than the its predecessor. So it could be that the SR-71B sounds much better than the Toucan, but I was just giving my perspective on the two amps. I don't want to create any confusion, and so will refrain from doing anything like this until I hear the Toucan as well. When the trusted reviews come in, I will be eagerly reading them.
Peak to peak is essentially just one way of doing a measurement of voltage, just like RMS (root mean square, or about 70% of peak power) and peak (which will be about 50% of peak to peak.) So yes, any power/voltage measurements are important.
