Djinnenjous
- May 23, 2014
I have most of my music files on a 128 gb microsd card, however I also have a few files on the dx90's internal storage. Eventually, I will have more music on another microsd, plugged into the USB via OTG.
When I am browsing through my music, using the "database" option - where I can browse by the subheading categories such as "artist", "album artist", "album", "genre", etc. etc. - I only see the music that is stored on my microsd card. The music that is in the internal memory is not showing up in the "database"
In order to access the music that is stored in the dx90 internal memory, I need to go into "files" and then choose the music from the files subheadings.
My question is, is there any way to integrate the music from my microsd card, the internal memory (and eventually from another card plugged into the USB via OTG) so that all the music shows up under "database"? It would be great to have an integrated list to select from, instead of having to look in each separate storage place.
Thanks for any guidance.
Is this with Rockbox or Lurker's firmware? Have you updated the DB recently?
I have this same issue, using the most recent version of Rockbox & 2.1.5 L2. For some reason Rockbox seems to prevent my internal memory's files from showing up in the normal song list. I'd be interested in a solution. I'm not sure what you mean by updated the database, though, since I only installed very recently. I still don't have a clue what I'm doing with Rockbox so I tend to leave it alone.
