Review: ZERO 24 BIT/192KHz DAC/Headphone Amp/Pre-Amp
Feb 23, 2008 at 1:15 PM Post #1,651 of 9,388
Originally Posted by pincellone /img/forum/go_quote.gif
I've reached the 100 hrs with my Zero and tried several opamp combinations. With my setup I have to say LT1364 + LME49720 is in fact the best combination you can get.
I'm using a Sennheiser HD-555 and a SB Audigy 2 ZS.
I've found the LME49720 to be more detailed then LT1469 in the AMP. The LT1364 in the DAC is unbeatable. A close competitor are a couple of OPA627BP on adaptor, but still it wins hands down.
BTW I also put an heatsink on each opamp, they can't do bad on them...
Great! That is good news! When you say the LT1364 is better in the DAC, is that listening to the DAC output to a separate amp, or what? Or was it just how it affects the built-in headphone amp? Thanks!
Feb 23, 2008 at 2:53 PM Post #1,652 of 9,388
Hi Penchum. I'm saying both.
I believe the LT1364 is the best option in the DAC when connected to an amp (I've tried the Super T-amp and the Panasonic SA-HE70).
At the same time, LT1369 in the DAC combined with 2 X LME49720 in the (zero) amp is the perfect match for me.
Also 2 X LT1469 are good but not the best for my setup. I've also tried several other combinations, as I have a few opamps laying around
I don't have the Audigy 2 Drive, but I'm using a toslink optical connection through a self made board connected to my Audigy 2 ZS, although I don't think this really matters.
Feb 23, 2008 at 3:22 PM Post #1,653 of 9,388
Cool! Are the Senn HD-555's considered bass heavy at all? Or are they the ones that are more like the 580,600,650 types?
Feb 23, 2008 at 3:56 PM Post #1,654 of 9,388
Thanks for your update, pincellone!
I guess I will try the 1364 again in my DAC. When I first tried it, the bass sounded bloated and boomy. The chip also ran hot (still need to order cooling fins!) in my Zero. Perhaps I was hasty or expecting too much from the chip and should give it another chance. I have been using the 1469 as DAC and 1361 in the amp section and find it very good - esp in the bass.
I am still waiting for a pair of 1028s to try and am hoping that they will arrive by mail today. It will be 10 days today since requesting.
And I just ordered a pair of 627s on adaptor, too!
Feb 23, 2008 at 4:31 PM Post #1,656 of 9,388
Very good edguetzow, keep us posted. I'm also waiting for a couple of 1028s.
To be honest with you LT1469+LT1361 didn't impress me that much, but of course results also depend on the particular setup and personal tastes.
The 627s in the DAC scored quite high in my personal rankings. They are my second best after the 1364.
Feb 23, 2008 at 4:47 PM Post #1,657 of 9,388
I didn't have the luck to try the others, but the HD-555 are very good value for money. Check this out
Review: Sennheiser HD 555 headphones
That's a good read. I remember now, that I was looking at the 555 to replace my old 280pros, for computer output use. I still might do that. I see no need to spend extra on 595s, when the 555 will do just fine.
Feb 23, 2008 at 4:52 PM Post #1,658 of 9,388
I was going to mention, that when my order from LT came, no 1028s were in it. I don't know if they ran out, and I'll receive them later, or if I'm out of luck.
Feb 23, 2008 at 5:07 PM Post #1,659 of 9,388
FYI, when I received my previous orders from LT, they were in separate shipments. My order came in 2 separate packets a couple of days apart.
Feb 23, 2008 at 5:11 PM Post #1,660 of 9,388
Ow, ok, great! I hope that happens.
I was all set to start swapping again.
Feb 23, 2008 at 7:06 PM Post #1,662 of 9,388
Smart thought Penchum. In fact, I believe that there are no audible differences between the 595 and the 555. The specs are pretty similar as you can see here:
Sennheiser Worldwide: HD 595 - HD 595
Sennheiser Worldwide: HD 555 - HD 555
But I'm not sure that you will be able to find the 555 in the U.S., I can't see it in the Senneheiser USA website:
Sennheiser USA - Audiophile
Fortunately, Ebay helps a lot. They are pretty cheap in Germany.
Feb 23, 2008 at 7:12 PM Post #1,663 of 9,388
Smart thought Penchum. In fact, I believe that there are not audible differences between the 595 and the 555. The specs are pretty similar as you can see here:
I have the 595's think they sound pretty good for the money but they are not as good as the hd600's!
Feb 23, 2008 at 8:08 PM Post #1,664 of 9,388
Ciao
I have the Akg701 and Sony MDR 7506 which I drive with the ProJect Headbox and I ask you:
-Zero DAC is a significant upgrade how to headphone amp?
- Zero Dac also improves the sound of Squeezebox and CD4000 old Marantz?
Thank you
Feb 23, 2008 at 11:19 PM Post #1,665 of 9,388
