guido
- Jul 3, 2003
It is suggested by Violectric to use the V800 with the volume knob at or near the maximum in order to avoid loss of digital data...read previous postings in this thread regarding this fact.
The V200 volume knob should be used instead and possibly within the 12-4 o-clock range [by adjusting gain via the jumpers]
Will that make a difference? The V800's volume knob has much smoother feeling as it feels like non-stepped attenuator. I used to set the V200 at max and use the V800's attenuator since it's digitally controlled, hence no cross-talk or whatever issue could occur. Unless you wanted to use the V200 as pre with different DAC then it's not suitable for that purpose.
