Kozwoz
- Nov 26, 2014
How does the V200 pair with the normal LCD4? Can't workout what the power delivery will be at 200 ohms but I suppose it will be enough?
Why 0.5W? V200 puts out 0.57W at 600 Ohm and 2.2W and 100 Ohm. In any case the LCD4 will get more than 0.5W if I'm not mistaken? Probably closer to a 1W?would recomend V280/281, recomended is 0,5W so it is on the limit
https://www.audeze.com/products/lcd-4
The V200 is what I'm looking for in terms of sound quality. It is smooth, punchy and powerful. At the moment I want to know how much power it will deliver to the LCD4 at 200 ohm. Music Path said 0.5W but looking at the specs this looks too low and I would suspect it gets closer to a 1W if not more. I'm not sure I want to go balanced with the V281. Does anyone know how can I contact Violectric? Can't seem to find contact information.@Kozwoz what is your goal? what are you trying to accomplish in terms of sound, signature? It's difficult to suggest a match without knowing what you are looking for.
Violectrics got back to me and told me me the V200 absolutely has enough power for the LCD4 and should output 1700mW at 200 Ohm which is still a lot but recommend going balanced with the V280/281 but thats no surprise.
