Lorspeaker
- Nov 29, 2010
yaap, when i pinched it off, it sound good with my IPAD....Lo Fi IPAD.
now i am at home using my audiogd dac n one fancy tube amp, the EVO sounded alittle bright on my setup,
and i went into my closet to look for my spare BEYER foam which is THINNER than this EVO foam...
hmmmm now it sounded just right to my ears...adds some intimacy than when its naked.
the more these cans are "burned" and used, the better it sounds.. so sweet on the imaging and vocals..
I tried Lorspeaker mention to remove the foam on the earcup just by pinching them off.. I was hopeful the soundstage can be even wider and crispier sounds (as I am actually very happy with it already driving from power amps), but quite surprising it didnt work out well...
the soundstage probably becomes so wide it loses the naturalness.. Vocals not as focused anymore.. more importantly, the bass becomes resonated and not as tight.. The differences are quite significant.. I urged those of you who have this cans to try this easy and reversible mod.. depending on source/amp and preferences, this mod might be suitable for some..
