steampunk
- Oct 27, 2009
MH1 - Black or White
I ordered them for 6€ on the Amazon Germany:
http://www.amazon.de/Sony-Ericsson-LiveSound-Premium-Headset/dp/B005GDVBAE/ref=sr_1_1?s=ce-de&ie=UTF8&qid=1406140709&sr=1-1&keywords=Sony+MH+1
I hope they are not fakes
thanks, they ridiculously cheap right now for some reason. Excited to try them. Is is necessary to mod them to get a good sound?
Like jekostas said, depending on the source you use, you might have to do one of a few things to get proper sound (because of the OMTP standard used on the 4 pole jack).
If you use one of the older sony ericsson phones, it will work right out of the box. Most of the other sources, will need one of a few fixes like:
-A zip tie around the middle button, which can be easily removed when you don't need it;
-Buy a TRRS smart adapter;
-Open the remote control and solder together the mic and ground wires (you can see a pic of it here)
-Re-cable them (if you find the cable too annoying)
This applies mostly to the MH-1s, since the MH-1C already have a CTIA standard 4 pole jack. In this case, you can however, re-cable if you want.
I just got them and I must agree that the cables are the worst thing I could ever imagine. A true nightmare.
At least I had [COLOR=000000]coincidentally[/COLOR] a adapter at home from my old Sony Ericsson
I am satisfied with the sound though. To me they are a pretty neutral and balanced pair of earphones, but they require a more power to get the volume. All in all a great addition to my collection!
Is there an easy way to recable them? If not these phones will only used as home device as they are very hard to handle in general,because of the cables.( not only the flat design but especially the asymmetry *anger*)
And do they change at all by burn in?
what's is the best upgrade to MH1 with the better quality and (very) slight morequantity Bass and same or better sound stage? I like this wide surround sound from these!
Better than the MH1 with more bass? Doesn't exist imo. The MH1 has some of the best mids and treble of any iem imo. If it's more sound stage you want though, I might recommend something with less mids. Not sure what though. I can't think of anything with more bass than the MH1 that I'd recommend.
Zero Audio Carbo Tenore is very similar with slightly better midrange and slightly less emphasized bass...
