Skylab
Reviewerus Prolificus
> Leckerton Audio UHA-6S
Info: Leckerton Audio - Products - UHA-6S
I received a loaner of the UHA-6S from Leckerton Audio. The UHA-6S is both a DAC and a headphone amp. It has both USB and Toslink optical inputs to the DAC, as well as an analog input, and the headphone output. There is a 2-position gain switch. The DAC is said to support up to 96/24 audio. As I have done throughout this process, my review was based on just the headphone amp from the analog input, but I did briefly test the DAC, and found it to offer excellent sound from both the USB and TOSLink inputs.
Build Quality: A: Very solid, sturdy metal case. Not really anything very exciting to look at but very solid. It had only a barely noticeable turn on “tick”, and was dead quiet. There is nothing sexy here, but definitely there IS good build quality.
Treble: A-: A slightly soft but very clean high end, and with good detail. Compared to the iQube, it lacks a little top end air and extension, but the treble is quite smooth otherwise and in general provides very good performance. Will be best not to pair it with dark sounding headphones, though.
Midrange: A: Mids were very slightly lush and warm, although in no way think or syrupy. And they were very transparent, and the overall the midrange sounded clean and transparent, lending the amp a very open sound. The acoustic guitar from Porcupine Tree’s “We Lost The Skyline” was extremely natural sounding, with real body to the guitar, and a great sense of presence on the strings.
Bass: A: Deep, tight, and well controlled. Compared to my reference amps, it was perhaps just a tiny bit fat in the bass in terms of weight. But the punchiness was not diminished, and the bass was in no way thick or slow, just a tiny bit overweight versus strictly neutral.
Neutrality: A-: As you can see from the above, the amp leans slightly toward the warm and mellow side, although this is not a defining trait. The overall performance is very smooth; but with a slightly downward-sloping character. Best with neutral or slightly lively headphones.
Soundstaging: A: Soundstaging I felt was excellent. Lateral image placement was well defined, and instruments had good solidity. Width and depth were very good. Just short of the absolute best, but nonetheless very good.
Transparency: A: This also was excellent. There was no grain, etch, veil, or any other anomaly in the way of the music. The UHA-6S was a very transparent amplifier with all of the headphones I tried.
As with the Linearrosa W3, I feel a little bad about judging the UHA-6S just as an amp using its analog input – but that is what my methodology has been for this entire review. There are better values in portable amps that do not have DACs. I would not buy the 6S if I did not plan to use the DAC. At $309, the UHA-6S is a very nice product, but faces some very stiff competition for what it delivers. I only recommend it for people who want a TOSlink input and where the slightly warm and mellow sound will make a good fit. A good solid product, but not a groundbreaker.
Conclusions (3-24-10)
OK, so now it’s now 51 amps! Here is my view on how the amps stacked up. Note that the sum of the "Grades" I give does not always tell the whole story in how I rank them, since the whole is sometimes greater or lesser than the sum of the parts, and I am often forced to split hairs here, since the list has gotten so long. Also please note that even if these amps include a DAC, that DAC performance was NOT a factor in these rankings AT ALL. Also, for clarification, this ranking is based on sound quality ONLY, and does not take things like size or battery life into account.
1. Triad Audio Lisa III @ $600.00; Power supply is $350 additional
2. Qables iQube @ $605.00
2. RSA Mustang P-51 (review here) @ $375.00
2. Larocco Audio Pocket Reference II mk 2 (availability unknown - PLEASE read entire review)
3. Headamp Pico @ $349.00
3. Meier Audio 2MOVE (and the older MOVE) (3MOVE @ $270.00)
3. iBasso Audio D4 Mamba @ $219 (Review Here )
4. RSA SR71 @ $395.00 (original SR71, not the SR71A)
4. RSA The Predator @ $475.00
5. RSA The Hornet “M” @ $370.00
5. Decware Zenhead @ $295.00
6. Xenos 1HA-EPC (discontinued)
7. RSA Tomahawk @ $295.00
7. Meier Audio XXS / Headsix @ $166.00/187.00
8. TTVJ Portable Millet Hybrid @ $459.00
8. iBasso D3 Python $219.00 (review here)
9. Xin Reference @ $279.99
9. Meier Audio Porta Corda III (discontinued)
9. Xin SuperMicro IV (current version auditioned 1/22/08) @ $199.99
10. ALO Double Mini3 (review here) @ $235.00
10. Headamp AE-2 @ $349.00
10. Graham Slee Voyager @ $233.00 + S&H from UK
10. Linearrosa W3 @ $299 (review here )
10. Leckerton Audio UHA-6S @ $309
11. iBasso D2 Boa $165.00 (review here)
11. Go-Vibe 7
11. Mini3 (Price depends on build) built @ $125.00
12. Leckerton Audio UHA-3 @ $189.00
12. iBasso T3 @ $119.00 (Review here)
13. Portaphile V2^2 @ $275.00
13. Linearrosa W1 (review here )
14. mSeed Spirit (discontinued)
14. Mini-Box E @ $229.00
15. Storm 3 (NOT B3) (review here)
15. Storm Little-2 (review here)
15. Storm B4
16. Visely HEA-4 @ $149.00 (Review here
16. iBasso P-1 (discontinued)
17. Visely HEA- 1 @ $135.00
18. Microshar uAmp107 @ $135.00
18. Practical Devices XM4 @ $135.00
18. C&C XO @ $209.00
19 Music Max LT1 $99 (Review here)
19. iBasso T2 (T4@ $109.00)
20. NuForce $99 (review here)
20. Go-Vibe 6 (discontinued)
21. Xtra X-1 Pro @ $104.00
22. Xenos 0HA-REP (discontinued)
22. iBasso T1 (discontinued)
23. Xtra X-1 (discontinued)
24. C&C Box V2
25. Storm B3
25. Little Dot Micro+ (discontinued)
As always, this is JUST MY OPINION, but I hope it has been helpful.
11. Go-Vibe 7
15. Storm B4
24. C&C Box V2
25. Storm B3
