sonitus mirus
- Mar 23, 2009
No, if you are not feeding the HDP a digital signal, either through USB or S/PDIF (coaxial or optical), there is nothing to convert.
Thank you for your response.
I have another question: I am using my Macbook Pro as part of my setup. There is a 3.5mm headphone jack which also allows for optical output. If I use the optical cable (TOSLINK) with the mini-adapter to connect the Macbook Pro to the HDP, then will the signal be considered as digital? And if so, will I be able to use the DAC feature of the HDP?
Thanks again.
Yes, absolutely, that will allow the HDP DAC circuitry to do its thing.
