dogears
O crap. I accidentally removed the filter... now it sounds treble happy
3M tape to the rescue...
I think the Etymotic filters may fit and who knows, it may sound even better with them.
as far as i know they aren't released yet, so no photos
FA representative said on local forum that cable would be the same as in Oldskool'70 model, and overall sound signature could be a bit less bright due to different body size
Drivers and filters are the same
What do you mean by filters?Where are there?(I have the MkI as well)
There is a porous filter placed in front of the BA unit inside the housings. You can't see it, but it's there. You can try to see it by shining a flashlight down the sound tube and see if you can catch a glimpse of the metal ring that houses the filters.
@tomscy, how 'porous' is it? I noticed that the original filter has some tiny holes in it when I put it against the light. I can count something like 4 holes. BTW, the 3M micropore tape is doing a great job as replacement. Something we use in the Fostex thread
Etymotic supposedly put a lot of thought into their green filters to get an accurate treble for their models. I have always wondered how it will sound with other BAs, but just haven't tested it, should fit any small nozzle BAs, just haven't tried. Been thinking about placing one on the heavily damped Klipsch X10.
I've replaced mine (broke the original through my own carelessness) using a straight Neutrik plug like this one. I used some wire insulation pulled over the DBA cable for the internal crimp and to act as the strain relief. Right angle is also available and doesn't require anything over the cable as strain relief. Both are relatively easy to solder.
