White Lotus
Reviewer for Stereo.net.au
- Mar 10, 2010
Off topic, but you are close by. Look through my inv, if you need to borrow any gear, you are more than welcome to.
Do you play games on your laptop or you use a console?So, I've had my Jaycar's for a few months now (my first real pair of headphones) and have been using them primarily for gaming and music (electronic and classic rock). I think they sound good but am not blown away by them. I'm running them off my laptop and am thinking of picking up this:
http://www.amazon.com/Pyle-PHE7AB-Portable-Headphone-Amplifier/dp/B004V9GPHS/ref=cm_cr_pr_product_top
To the best of my knowledge, it's essentially a FiiO E7. Anyone know how the FA-003's/Jaycar's/HM5's respond to the E7? Do you think it's worth it? Will I be able to tell a difference?
I play strictly on my computer. Glad to hear this DAC/Amp works well with the Jaycars. Do you think the difference in sound is worth the $60? Keep in mind I'm not a huge audiophile so really, really minor differences probably won't be super noticeable for me. With that said, I have definitely noticed a difference between my Jaycars and my old setup so I'm not totally oblivious.
Would I need anything else or is this DAC/Amp all I need?
Power Requirements The HM5 has 64 ohm nominal impedance - but what surprised me is how sensitive these are. They are absolutely ridiculously easy to drive. Straight out of my iPhone (unamped) my 32 ohm MS1is take almost exactly 50% volume for a nice listening volume. The HM5 at 64 ohm use the same volume. They do sound wonderful out of the NFB-12 - but I have to use low gain or they go too low on the pot.
Again, the Jaycar's are a decent pair of headphones, but if you want something that can give you the "WOW" factor, look into a pair of Denon D2000's,
Agreed. Although, the price difference between those two is literally hundreds upon hundreds of dollars - are you sure that's a fair substitute?
On an unrelated note, does anyone know if the FA003 cups fit on any other headphones? It's a shame to see such nice wood options limited to these!
I would argue that the Creative Aurvana Live and M50 are both more engaging headphones than the FA-003.
I know that the FA-003 cups fit with no mods on the JVC SA500, Denon D2000 (so I would guess they would fit on the wooden D5k and D7k as well), as well as the ATH-M50s.
Agreed!
Woah, are you sure? The D2K (D5k, D7k) all have circular cups:
Whereas the FA-003 are oval-shaped:
The PADS however, are definitely compatible with both (I use FA-003 pads on my D5k, and love them).
