Please see here: https://www.head-fi.org/threads/reveal-plugins-dsp-for-audeze-headphones.864146/page-2#post-13828923Hi
How do I use this with APO/Peace?
Searching this thread for 'APO' will also give you some results related to this
Hi, new user here. Im enjoying these plugins with my LCD2C on windows, the thing is, im planning on buying LCDi4 to have a portable HP and i have an android phone. I read that Roon supports the plugin, is it available for android?, does Roon supports the plugin on iphone/ipad or only on Mac?Reveal is a PC/Mac plugin, not an app so it is not compatible with iOs or Android.
If you want to use reveal with Tidal (app) on PC, you can use Equalizer APO and add Reveal plugin to it
On Mac to use with Tidal App, use AudioHijack or Menubus, then add Reveal. You can also try A+ for Mac that supports AU plugin.
Roon is another option and has Audeze presets built in.
You can search this thread to find more about the above.
There is No Android version of the plugin, but you can use Roon on android with the Audeze presets in Roon.Hi, new user here. Im enjoying these plugins with my LCD2C on windows, the thing is, im planning on buying LCDi4 to have a portable HP and i have an android phone. I read that Roon supports the plugin, is it available for android?, does Roon supports the plugin on iphone/ipad or only on Mac?
Is there any portable way to make it work on android phones? (like buying a portable DAC thats compatible)
I would love to have 10 band equalizer settings for LCD2C and LCDi4 so i can at least mimic the plugin on android
Are there any parametric eq settings for these models?
Anyone selling LCDi4?
Thanks
Ok, I'm not familiar with Roon app or software. I know you can use reveal settings with Roon, I checked their site and it appears that when using mobile devices, it streams the content from a "core". Correct me if I'm wrong, but what I need to know is if Roon would play music files directly from my Android phone with the reveal setting enabled.There is No Android version of the plugin, but you can use Roon on android with the Audeze presets in Roon.
@KMann Roon upscales to 64 bit and then back down to 32 bit when applying the Audeze presets. Can I use the Reveal App instead to avoid this extra processing? Most high end dac manufacturers recommend using bit perfect streams and not upscaling through Roon or MQA before sending to the DAC.
@KMannLooks like the latest firmware from Astell & Kern will support custom EQ for headphones. It this something Audeze could support?
- EQ Sync Function - ability to save and export EQ settings and share with others. Ability to import custom EQ settings. Headphone manufacturers can also release customized EQ settings to match their headphones to our players.
Stay updated on Audeze at their sponsor profile on Head-Fi.
We are open to working with A&K .
You could try this instead: https://rogueamoeba.com/soundsource/hey anyone found a way to run this on Mac OS 10.15 Catalina? I was using MenuBus but its discontinued and I don't think its 64bit. I know I can get it going with Roon but I am not ready to make that purchase yet. Would be nice to find a way to run it free, something Menubus but 64bit.
Turn it it all the way to 100% Wet. We make subtle changes only as they are already close to neutral and all the changes are in the audible range below 10kHz . Whether or not you notice a change will depend on the type of music, but look for slight increase in Bass (to match speakers in the room) and also look for changes in the upper mid-range/lower treble region.I gave AUDEZE Reveal a try using OSX Audirvana (latest version) all works as it should, but for the life of me I can't decern any differences btw DRY and WET settings (gains works obviously), I have LCD-X and LCD2-C and using the first track of The Ultimate Headphone Demonstration Disc which contains plenty of cymbals and drums among other instruments, in my system I can't hear any differences. Maybe I'm getting told old for that hobby.
yep I saw that. I am hoping to find something free.You could try this instead: https://rogueamoeba.com/soundsource/
