Radsone EarStudio ES100
Discussion in 'Portable Headphone Amps' started by m4rkw, Dec 12, 2017.
161 162 163 164 165 166 167 168 169 170
172 173 174 175 176 177 178 179 180 181
  1. Elzizo
    Try the Hiby Player. Very powerful and easy to use.
  2. harpo1
    None. It's a digital signal sent via the bluetooth chip.
    monsieurfromag3 and berzerk428 like this.
  3. PiSkyHiFi
    Well kind of, if it's Android and it's using Android's default output, then a signal coming from a music app may need to be re-sampled before being mixed to 48KHz 24 bit unless the app first reads and possibly adjusts the output format and possibly isolating it from being mixed too.
    There are a number of ways so despite Neutron's rather verbose interface, it's sound quality can be forced in most cases to audiophile, where it can manage the entire pipeline itself or just the resampling if you like.
    I'm sure other players can too, but some will not.
    You should definitely consider not using any third party eq only filter apps in combination.
    Edit: Oh and if you do currently want the best DSP like 3d or crossfeed and/or parametric eq, Neutron is a great choice
    trellus and berzerk428 like this.
  4. bavinck
    I agree Neutrons UI isn't awesome. But with it you know it doesn't allow your phone to do anything stupid with the audio signal, which most (all?) other players allow.
  5. bidn
    Hi berzerk428,
    There are plenty of ways through which the apps alter the digital signal:
    First there is the decoding performed by the app when the format is not natively supported by Android, e.g. the APE format. If you look up the info re. the aimp app in playstore you will see dozens of formats not supported by Android.
    Second there is all the sound shaping and processing performed at the app level:
    - fading at the end and begin of tracks
    - balance
    - own equalizer ( taking aimp again as example, it has a 14 band parametric equalizer)
    - all kind of special audio effects, etc.
    I have heard differences between apps.
    In the end I have settled for aimp when I don't need the USB-DAC mode, i.e. for the wired and Bluetooth modes, and for Onkyo HF-player for the USB-DAC mode.
    I agree that Neutron is a fine and very customizable app, but I don't find it handy enough.
  6. (zcus)
    Does anybody use the Radsone music player pro? It has the same DCT and EQ as in the ES100 app.. The DCT sounds radically different than the ES100 app version - also music seems to sound better through the Randson music player to my ears. Might it be optimized for the ES100 or is it just coloring the sound?
    bidn likes this.
  7. crazyeva
    Mine is like this:
    [​IMG]
    [​IMG]
    By the way, is it possible to change direction of its clip. I think it will be more convenient to attach it to my shirt if the clip is upside down.
    niron, trellus, Matarro and 3 others like this.
  8. Koolpep
    This was discussed earlier before (I am with you here, for me it's the exact wrong way!) - unfortunately the answer is no. Hopefully in the ES100 successor.
    Cheers.
  9. SteveOliver
    I like the short cable. :) Perhaps you could pop the cover with the clip off put it back the other way, I've not done this myself though so I have no idea if its easy or even possible to do.
  10. crazyeva
    I have this thought in head for days, but I may totally destroy it. Maybe I should just wait until it's popular enough to have a thread from ifixit.com
  11. zolom
    With the ES100 playing Tidal hifi, Found Usb Audio Player Pro to provide better audio than the native Tidal app.
    trellus and bidn like this.
  12. SteveOliver
    So I tried it (I like taking stuff apart anyway) the cover comes off easily enough, unfortunately the clips are not symmetrical so it won't clip on the other way, without some serious modifications. :frowning2:
    trellus and scotvl like this.
  13. smorgar
    Is it possible to fit a larger or thicker battery?
  14. PiSkyHiFi
    Be aware that these batteries are in a bag for a reason, they may need to expand and if they can't, they can catch fire.
  15. SteveOliver
    That was my thought too. I do have a suitable battery that looks like it may fit, watch this space.
