Liu Junyuan
- May 22, 2014
Yeah. And they are a really great value at their current selling price. Now the question is which color will you get?
That should be good. I used them with a Modi and my O2, which actually sounded superior to the Lyr.
Many people on this forum have praised the Q's synergy with the Matrix M-stage amp/dac combo as well.
A third option would be to perform the bass port mod. Check the first post in this thread for details.
Originally Posted by Boogirl /img/forum/go_quote.gif
K712s vs [Q701 + iFI iCAN]
If the problem is the Q701s then I am considering the K712s, since they are said to be similar but with an increase in the low end by 3db. However, there is another solution to deal with the lack of low end on the Q701s that I am interested in, which is to pair them with the iFI iCAN headphone amp. This option offers a 3db and 6db bass boost switch, and I have read in many reviews that this pairing really deals with lack of bass on the Q701s, giving them a really good bass boost without affecting the overall sound.
Both solutions are offering a better low end, therefore could anyone advise regarding the pros and cons of each solution: An upgrade to the K712s vs Pairing the iFI iCANs (with bass boost on) with the Q701s.
I am interested primarily regarding how the low end would compare, but also in the overall sound. Any comments would be welcome.
Here's another vote for the bass port mod. Plenty of bass for movies and gaming too.
You need to unleash the bass in the drivers with the bass port mod. It takes 10 minutes, is completely reversible, and makes a very noticeable difference in the low end without sacrificing any of the clarity or air for which the Q701s are routinely praised.
Another option is to try EQing them, assuming you're listening from a PC. There's a 30+ band Graphic EQ component for foobar2000. It's all free, so may as well try it.
Right, the bass mod is simple to do and undo, not a permanent change.
Re: Q701 vs K712
Both were flagship models of their time, the Q701 isn't even that old. Audiophiles bought them as the least expensive flagship model (while being flagship level they also offered their own distinct character and best-of strengths, HD800 was the first headphone to outdo them for sheer soundstage) and then completed their setups with amps and DACs costing as much or more as the headphones. They're both extremely good. If you have both side-by-side, the (first world) problem is the K712 is just a bit smoother, fuller-bodied while being just as clear, possibly slightly more detailed/effortless, and more comfortable in the headband, but you also want the Q701 because with headband wraps and a synergistic system both headphones are on the same technical capability level and the Q701 is significantly less expensive.
I'm stuck in limbo, owning both, hahaha.
Thanks for this. I have just compared the sound on my Q701s when driven by my Cambridge Stereo Integrated Amp to how they sound when driven by my Audio GD, and I am surprised to say that I am now having second thoughts regarding what I wrote about Q701 having a lack of low end. On the Cambridge, I am finding the low end to be very pleasing, not too unlike how – in an earlier post – I described I heard it through my loud speakers. Interestingly enough, my loud speakers are also being driven by the Cambridge, so the dots are joining together for me, so to speak.
Is it possible that all this time I have been unjustly blaming the Q701s for lack of low end, when in actual fact the problem is stemming from the Audio GD NFB-15 and not the Q701s?
Is the low end issue on the Q701s, in actual fact synergistic problem like you say? I think you may quite possibly be right with this... Maybe I should be looking at other headphone amps and not just the iFi iCANs.
