DaveK1977
- Aug 24, 2014
Yeah. And they are a really great value at their current selling price. Now the question is which color will you get?
Green. It should always be green.
You'll find that some amps might list impedance values vs. wattage outputs that don't necessarily calculate the way you'd expect. One factor affecting this is a low impedance headphone simply causing the amp to run out of current. Also, variations in the impedance across frequencies can cause power matching drops to occur, where you might not have enough drive in one area or too much in another. After running into the various gear I have not driving the low end correctly (except for my FiiO E18, which is perfectly fine) I might get a different audio interface for my DAW/PC that can drive a wider array of monitor headphones. I'm also thinking of getting a set of closed Beyerdynamics (DT770) at either 80 or 32 Ohms impedance, and want to make sure I can drive them correctly when tracking and mixing.
Variations in impedance DO NOT cause "power matching" drops to occur in a properly designed headphone amp.
A well designed headphone amp WILL NOT have a problem driving a headphone with large impedance swings.
An ideal headphone amp will have a very low output impedance, and more than enough output voltage and output current to drive almost any headphone to any rational volume.
Are you kidding me? You haven't seen ANY charts showcasing has impedance can vary at given frequencies, thus affecting power delivery and damping? Good job. I love all the electrical engineers here...
However, in ANY case having a poor "match" (not a power transfer match, but more of a multiple of impedance "match" between the amp output interface and the headphone connection) can be heard in poor driver control. So even in your poor attempt at mocking, you did manage to prove my point by referencing the "ideal" headphone amp and headphone pairing. Again, good job.
TL;DR.... . .![]()
. . .On a side note, the build quality is terrible for the price you pay. I hear creaking sound every time I move my jaw. -_-
Why thanks for your positive feedback, guys! You're too kind. I just know that some of you were probably thrown off when I compared the Q701 to the M50. They're so different! But somehow, it seems right when I look at the M50 and add some AD700 aspects to it. Or maybe not. More impressions soon!![]()
