- Mar 20, 2010
The headband does hurt at first. I say in less than a week your head will adjust, and then you won't feel them anymore.
ATTENTION Q701 OWNERS = Could you lend a rookie some specific advice?
I removed the Q701 foam and installed two K701 foam pieces (different part #). The Q701 foam is definitely not the reason it sounds different than the K701/K702. As mentioned earlier, the Q701 and K702 share the same foam.
With the K701/K601 foam it takes the edge off slightly. It's clearly a difference and you can try it if you want. There seems to be a tiny bit of extra bass. The Q701 is perfectly good as it is, but the K701 foam SEEMS to make it even smoother.
I've been listening to the Q701 with the K701 foam non-stop for the last few days and the whole time I'm thinking to myself..why on earth does this sound so much better..has to be placebo right?
I've never seen the K701 foam up close, but I don't think it's that different from the Q701 foam. They should be very similar, right? I'd have to see pictures of them. Is the part number different from the K702s? Because those looked so close to the Q701 foam that I didn't even bother switching because I couldn't tell them apart -- the the sound difference would be insignificant.
I would bet the differences in sound between the two would be pretty small. I'm not saying it is placebo, but you could probably easily trick yourself into thinking it sounds better/different because you're just listening closer trying to hear differences.
Either way, I for one don't want the Q701 any smoother. I think it's plenty smooth as it is. I don't want any more airy-ness taken away. I'll just switch to a warmer headphone if I want that.
Is there any online music I can try that will demonstrate what these headphones can do? Strangly enough the only thing I have really enjoyed listening to is the ultrasone demo flacs. All my music sounds like I remember it. Its all 128 mp3s so maybe since I am used to it sounding like crap I dont notice it.
