PSB M4U1 - Thoughts?
Oct 5, 2015 at 3:13 PM Post #421 of 630
Don't get me wrong. It's not that they're uncomfortable or sound bad. For portable cans they sound very good. And are pretty comfortable. It's just that my non-portable gear sounds so much better I'd like to shorten the gap between them. For home fostex th900 (fully moded) with cavalli liquid glass and premium tubes. My portable is PSB powered by dx90. I've already changed the cable to an eberry with noticeable improvement. I have two PSBs, one for my wife, so I can do easy a/b comparisons. One is slightly less comfortable. I'll mod that one. But if I could find alternative ear pads to try that would be great. When the ear pads break in they will only get flatter. And less comfortable. That's why they gave us extra pairs. If I can find a good alternative I won't have to rebuild these ear pads.
You set the Bar so high at Home.
    Have you tried the PSB's with your home rig? WIth Tubes in the Mix I would be curious if the PSB's sounded close to the th900's on your home rig. Getting a tube sound on the go may be hard
I have not seen many mods outside of the cabling. And I am not that adventurous to tear mine apart. A pad swap may be interesting. Since your current pads are worn maybe removing some of cloth in front of the drivers would change things a Bit. I saw some people do things like that in the Grado threads. I have not seen any aftermarket direct replacements maybe some people know of others that may be subbed ??
Oct 6, 2015 at 12:39 AM Post #422 of 630
You set the Bar so high at Home. :L3000:     Have you tried the PSB's with your home rig? WIth Tubes in the Mix I would be curious if the PSB's sounded close to the th900's on your home rig. Getting a tube sound on the go may be hard
I have tried the PSB with the my liquid glass amp and it didn't fare so well. I think it hits its ceiling with the dx90. That's ok. I do still really enjoy the PSB. I decided to go ahead with the mod attempt. And it worked beautifully. I can't say it'd recommend this to anyone. I thought I might be able to remove the plate over the driver using the 4 screws. But I removed the screws and discovered that the speaker is permanently adhered the the cover plate. So I replaced it very carefully. I don't recommend anyone remove this plate. Real damage could be done. But I decided to try to enlarge the holes using a Dremel tool. I very carefully cut away at as much plastic as I dare. The diaphragm is very delicate and clear, so it is practically invisible. I did this to one of my PSBs first and then did an A/B comparison. I have two of them. For me and my wife. Before the mod the were identical except that one was less comfortable. That's the one modified. Before the mood their sound was identical. After, the modified PSB has more detail, more natural voice, more volume/efficiency. Better timbre. More bass. AND I was surprised to discover that the moded phone is more comfortable too. I feel like the phone is better in every way. I'm definitely going to cut up the other one too.
400
[/IMG]
Oct 6, 2015 at 12:41 AM Post #423 of 630
400
[/IMG]
Oct 8, 2015 at 10:14 PM Post #425 of 630
With regard to the stridency of the M4U1s, I haven't used them straight from my phone, but it wasn't much of an issue with the FiiO E07K DAC/amp due to the warmth of the amp section. It did become an issue when I added the clean sounding Pro-Ject Head Box S amp and used the FiiO as a DAC only via the L7 line out adaptor. Substituting the Pro-Ject DAC Box S USB I grabbed this week banished any hint of such treble sharpness, although it possibly loses a smidgeon of detail and sparkle up top to the FiiO as DAC. In all other respects the Pro-Ject DAC bests the FiiO, as you'd expect, but not by a huge margin. They both recognise the flac feed from my phone via OTG usb. In my view the PSBs scale up very well with better recordings, sources and amplification. They are just so transparent.
Oct 9, 2015 at 6:24 AM Post #426 of 630
iFi micro iTUBE>>>iFi micro iCAN>>>PSB M4U 1 is really addicting. Even with the XBass on the iCAN at the maximum level, details are still very clear on the M4U1. Can't believe why I decided to get the 2 gears just now.
Oct 11, 2015 at 4:38 PM Post #427 of 630
I ran across this Cable from FIIO . According to the website It is OCC copper. There are two different ends. One with a very thin 3.5mm jack that slides perfectly into the M4U1 Jack and the other end is a nice silver metal one that would go to you source. Its $28 on amazon with free shipping. Its about 4 feet long. I do hear a very noticeable decrease in sibilance as opposed to the stock cable. I was shooting for the Oyaide mentioned earlier. but in my research I came across this one and figures I would give it a shot.
http://www.fiio.net/en/products/22
http://www.amazon.com/gp/product/B00GGL5TKI?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01.
I still have not grown the stones to hack into the psb's for any modding otherwise.
Oct 12, 2015 at 1:04 AM Post #428 of 630
The OCC cable I posted on the last page came in (yay!), but the connectors were still on their way so I decided to use it for my Grado SR60i that needed a new cable and wait for the 2nd cable to arrive to do the M4U1. All I can say is that I am expecting greatness when I do up the PSBs as the cable I got from China significantly improved any shortcomings of the SR60i. I have 2 pairs, one modded with the 3 holes and one that wasn't (that needed recabling). After I did up the wires I was shocked at how much the sound improved; Bass is kicked up a notch and cleaned up significantly (so much so it is on par with the 3 hole mod), the mids became more smooth and open and the treble lost quite a bit of the Grado bite. The 3.5mm plugs arrived 2 days later than the cable, and I wish I had held off and did the PSBs.
In short, an OCC cable (with dual plugs) is the key to greatness for the M4U1.
Oct 12, 2015 at 10:38 AM Post #429 of 630
With Dual plugs.... You are killing me here.
I had a Pair of Grado SR80's. I could not get over the mid high bump it made them almost unbearable.
Oct 13, 2015 at 6:05 PM Post #430 of 630
FiiO cable uses the same supplier of the OCC material (Furukawa IIRC) as Oyaide.
Oct 22, 2015 at 5:40 PM Post #432 of 630
Got to do a bunch of A/B testing with a few friends at work : m4u1 compared with oppo pm-3 and b&w p7 and Senn Momentum over ear. Interesting stuff and I'll post complete thoughts later (I'm demoing pm-3 as part of oppo loaner program), but the PSBs show the best mix of sound quality, comfort and easy drivability. We all suspect the PM-3s would please more people more of the time driven by a quality dac/amp chain (and they're nice as heck, design and build-wise), but straight from a laptop or smartphone, the PSBs really shine.
That said, has anyone tried the M4U1 with a cozoy Astrapi or Oppo ha-2?
I'm thinking of buying a relatively low cost dac/amp. Primarily this would be for desktop use with a MacBook, but I'd like it to pull double duty with iOS devices.
Would also want to drive my Ety ER4S with it.
If you want to save money WITHOUT losing in incremental SQ improvement, iPhone 6+>>FiiO E12 is really kind of end game. If you like bit forward/emphasized mids/vocals, FiiO E12A. Just make sure you always put iPhone volume to maximum.
Oct 22, 2015 at 6:38 PM Post #433 of 630
   Now If I can get that whole dual plug thing out of my head.
My next post won't help with this...at all!
Oct 22, 2015 at 7:54 PM Post #434 of 630
Heyas good folk! The parts came in from China and I finally got my new cable constructed! I have had it done for a few days but I wanted to get a full set of testing done before I post anything. First off, as much as my previous posts were genuine and honest in regards to my impressions on the increased sound quality between cables, forget everything I said! My new OCC dual plug balanced cable is a whole new beast!
But first, a few pictures. Sorry for the potato quality, the ambient lighting was at the perfect level that my 6th gen iPod hates.
The Preparation
First Impressions on build quality:
My first impression was that of worry. The cable was the size of the Sennheiser IE80. I knew I ordered essentially an IEM DIY replacement cable, but the pictures made the thickness seem beefier than it was. After re-wiring my one of my SR60i and A/B'n the stock cable vs the new one, all worries went out the door.
The cable is very light, and essentially feels invisible when dangling from the cups. Construction wise, while light feels very durable. The outer cable casing does not feel cheap, and both the metal plug and the y-split relief feel like they will out live the cable. Microphonics are literally absent; No matter what the cable rubs on (shirt, collar, chair, beard) or even if I tap the cord, it is dead silent!
In terms of any EMI/RFI, the cable offers none. Moving the cable close to my WiFi router and cordless phone, I could hear nothing but a dead black background. Not only are the OCC strands twisted, they are coated with a non-conductive teflon-esque material, and the signal/return wires themselves are twisted, so there is no need for elaborate shielding that are required for straight leads.
The Sound:
One word: MAGIC!
Game over, I am done! See ya'll later!
OK ok, I will elaborate.
Speed: The first major change I noticed was the increase in speed. Not just the lower frequencies, but across the whole spectrum! I never in a thousand years would expect a cable to increase the speed of a dynamic transducer, but it did, and not in a subtile way either. The added speed is very tangible, I would even go so far as to say visceral.
Bass: The mid-Bass definitely slams harder, and the sub-Bass (while not as increased) has added weight. Thanks to the increase of speed, the added control on the bass is simply astounding. I would say a good 1.25dB gain and 100% added control.
Mids: The mids were always pretty smooth and detailed, but the new cable added a good dose of body and added transparency. I hate to say it, but even with my Audiophile OFC interconnects, as well as my previous custom cables, there was invisible grain. I never noticed it before, but after the OCC upgrade, it becomes quite apparent. It was especially prevalent in the upper-mids (i.e. female vocals) but that is all gone.
Treble: OMG! Pure bliss! I am now hearing the nano-details I have only heard with beyerdynamic's Tesla series drivers. Dead serious here! Not only does the treble come across as more airy, the detail just pops! Again, thanks to the added speed, the treble is very controlled. No glare, no peakiness!
Soundstage: While the left/right and the up/down space remained virtually the same in comparison to my old custom cable (which was significantly better than the stock cable), what was significantly increased was the depth. Listening to some of Chesky's test tracks sound even more lifelike and amazing. My ears may have flinched before when Edgar the Barber was giving me a virtual haircut, now they curl!
Transparency: Metaphors best describe the added transparency. The stock cable is like a dirty pane of glass. Upgrading to (virtually) any aftermarket cable is like wiping the pane of glass with your sleeve to clean it. Upgrading to an audiophile/custom cable is like using Windex and a soft chamois to clean the glass. The OCC cable is equivalent to outright taking away the glass altogether!
Volume increase and the break-up of sound: This is kind of an off-ball category, but is worth a mention as it is not only a big factor, but one that many professional reviewers have given the M4U 1 a negative for (usually their ONLY negative). At higher volumes, the sound tends to not sound as smooth, and at loud volumes tend to break-up. The most noticeable degradation of sound is that of peakiness, greatly effecting sibilance (both harshness and stridency), adding glare to the upper registers of instruments, and generally taking away from the overall transparency. The OCC cable completely remedies this! I listened to my M4U 1 for 3 hours straight last night at a level that would make most audiophiles cringe, and my ears heard nothing but euphoric bliss! I could have easily listened for another 2 hours but it was already very late and sleep was a good option.
Well, that's about it. In closing, if anyone is interested in a cost effective way of significantly increasing the performance of your M4U 1 (or any headphone for that matter) I suggest taking the route I took. Seriously, $15 total cost! One does not need to be an expert in soldering to make this happen, but if anyone is unsure, or unequipped to make your own cable, PM me and we can arrange for delivery to me and I will gladly make one up for you and ship it (assuming you live in North America, it should be a couple dollars shipping from me to you). Anyway, I am off to enjoy the fruits of my labour!
