Thanks guys!
Nice build! Are you still working on the power supply? I liked the craftsmanship of the volume knob illumination ring. Would you care to share your technique for creating this ring?
The psu was done a while ago, it’s dual duty for the EHHA and β22
http://www.head-fi.org/forum/thread/85561/post-pics-of-your-builds/6735#post_6549866
The illuminated ring is simply a 37mm cavity hole bored to 7mm (panel is 10mm thick). Two 37mm frosted perspex rings (3mm thick) are placed in the cavity with the centre hole cut out. I used two pieces of perspex as it spreads light evenly, you could use one piece and have the knob inset further into the panel. A front panel bearing bush locks everything into place. A LED from each amp board is used for the 4 LEDs and glued into place. The knob is a 30mm dact.
This is kind of what the panel looks like without the perspex.
![](https://www.head-fi.org/attachments/90931/)
and this is a work on progress with the shaft not yet cut, to give you a better idea...
Beautiful John. Did you get the case from Italy or local?
I bought the front panel and side flanks from Modushop, the top, bottom and back were all done at Cam-Expert.
Owen, my previous β22 was sold, the reason I built another besides insanity... I’ll explain...
My old β22’s psu was not up to scratch for speaker duty when building my EHHA, so I build another hefty sigma22 for the EHHA. I sold the old β22/sigma22 and re-built this new amp section with those funds.
