Beefy
- Mar 4, 2008
I would think that an M right over the top of each pair of MOSFETs would be entirely appropriate
Originally Posted by oneplustwo /img/forum/go_quote.gif Hey folks, I finished the boards for my M3 and S11 build. Now I'm getting ready to tackle the casework. The amp and power supply are going into their own Hammond cases. So I was thinking about milling out three M's on top of the amp case right above the heat sinks (one "M" for each pair). (I just picked up a mini mill from Harbor Freight for all of my miscellaneous projects.) I was also going to try some semi-fancy slotting on the sigma. Anyone have any creative ideas I can steal? I haven't seen too much in the area of custom milled casework/vents so I thought I'd poke around for some inspiration. |
Originally Posted by KevCanHead /img/forum/go_quote.gif Finally got around to posting some pictures of my SOHA Was a Kit from Jeff At GlassJar Audio and worked a treat from the start and I am still loving it, literally a I type |
NSX 23 - did the casing come with the panels drilled already? |
NSX 23 - Also, is your H140 painted by any chance? |
Forte - Looks great, How easy is it to change tubes with the tube protector in place? |
Originally Posted by Hayduke /img/forum/go_quote.gif I like the 3 M's idea. I'm doing something similar with my SOHA II (once my friend that offered to do the machine has time). If you're looking for ideas for the sigma's enclosure, how about a sigma symbol then 11? Seems appropriate and in keeping with the M3's theme |
Originally Posted by oneplustwo /img/forum/go_quote.gif I think I might do the uppercase backwards "3" looking sigma (since it's straight lines). I might just do two of those, one for each heat sink. Just because I think the layout makes it look cleaner vs. using an 11. Also, for the "M" I'm just going to use the font that amb used on the PCB itself. Thankfully, it's also made up of straight lines. I may fatten it up a little bit, but hopefully it stays recognizable as the same font. I'll try to get to some of it tonight so I have pictures to show. |
Originally Posted by Ferrari /img/forum/go_quote.gif Good to have vents on top of your amp and PS, right above the heatsinks, and vents that reflect the name of the amp is of course a big plus! But better is also to have some vents (ordinary holes) beneath the heatsinks to provide good air convection. My σ11 PS is housed in an enclosure with good air convection, straight and simple as usual. |
Originally Posted by oneplustwo /img/forum/go_quote.gif Ferrari, I was thinking about holes directly under the heat sinks, but the board is in the way so I wasn't sure it was going to make a big difference if they were directly under the heat sinks or off to the side a bit (or even there at all if the slots on top were pretty big.) I guess more venting couldn't hurt anyway. I might as well do both the top and bottom at the same time... just clamp it all in the mill together. |
