Originally Posted by Heady /img/forum/go_quote.gif I don't think those yellow caps are 10uF capacitors. Haven't seen 10uF caps so small. At least not those I have seen. Would you like to take a closeup of the caps?
ow... my apologies, those are 100µF caps... edited.
Sorry
I've heard that those small polyester caps are worse then the bigger ones. (100µF as well)
The clock was a fun project, I designed it using 6 steps of cascading 4017 chips. Still need to get around to putting a crystal in though because right now it's on a pot adjusted 555 which is nearly impossible to get a good speed on.
Cases are just aluminum enclosures made by Hammond that I got from Antique Electronic Supply. They work great for tube amps since they are a good thin form at 2".
Since people seem interested in the clock here are some picts of that
60hz powerline clocking is a possible solution that I also considered, I'm not sure how reliable the clocking is on the mains here though. I read in other countries it's based on an atomic clock for longterm but I couldn't find anything about the US 60hz base
