Post A Photograph Of Your Turntable
294 295 296 297 298 299 300 301 302 303
305 306 307 308 309 310 311 312 313 314
  1. Funambulistic
    That is an AWESOME setup! Congrats and good listening!
  2. analogsurviver
    I should have written the exact description of the Technics B500 base, EPA-501H, EPA-501G, EPA-501M, EPA-501E, EPA-501P, ...
    http://www.vinylengine.com/library/technics/epa-500.shtml
    there are six wands in the series, 5 for normal 1/2" mount, one for T4P P-Mount cartridges. For various cartridge mass/compliance combinations - BUT ALL WITH FIXED ANTIRESONATOR FREQUENCIES AND Qs . It is not perfectly adjustable as with EPA-100 , EPA 100MK2 ( by far the best of the bunch - about triple the price of its siblings ) or EPA-250
    http://www.vinylengine.com/library/technics/epa-250.shtml
     ( which is also part of the EPA-500 system, fitting the B-500 base and sporting S- arm tube, removable IEC headshell and adjustable frequency ( and Q ? ) of the antiresonator ). The most common EPA 500 wand is EPA-501H ( which I own ) - which was a perfect match for the Benz MC Reference some 15 years ago ( pre - Lukaschek times, when the compliance was higher ) - but it usually pairs well with a cart of lower mass and higher compliance. All 500 antiresonators are set to the frequency approx 10 Hz ( except E, which is for highest compliance carts, which require for resonant frequency of 10 Hz zero - or even negative - tonarm effective mass, therefore antiresonator is set to a frequency that is practical in such cases - around 7 Hz ). EPA-501H was the want supplied by default as the "EPA-500" tonearm - and other, much rarer wands may in today*s market burn a larger hole in your pocket than ( B500+EPA501H = EPA 500 ) would.
    EPA 500 series is the worst sounding of all EPAs with antiresonator - due to structural resonances within the audio band. But it is possible to DIY them out, bringing the arm(s) to an entirely different level.
    Koetsu/Graham is no different in fundamental cartridge suspension compliance/tonearm + cartridge effective mass resonance ( ideally at 10 Hz ) than any of the normal arms - it is no match for the properly adjusted/matched EPAs. Once heard the effect of amelioration - or, in really good cases, complete elimination  of  - that fundamental "10 Hz resonance", it is difficult to go back to anything that does not allow for its suppression - regardless how good it might be otherwise.
    With any of the methods that bring the fundamental resonance close to zero, the woofers will stand "still" ; however, the lower the frequency of this (even compensated for ) resonance, the higher will be the effects of the warps. The only system known to me that does succeed in overcoming this almost-taken-for-granted weakness of the vinyl playback is Transcriptors Vestigal arm ( as the first that did it ) - or, as I have put it upon first seeing/working with it "finally a well executed Vestigal " - the Versa Dynamics TURNTABLE SYSTEM. Both of these arms employ extremely low effective length in vertical sense ( I doubt you can mount the Koetsu on Versa - not enough room for connectors due to long(ish) cartridge body ) - but only if and when used with very low mass cartridges with high compliance.  The reason is the little known and even less understood term of SEESAW FREQUENCY - which is the frequency at which the tonearm fitted with cartridge set to track at zero tracking force oscillates if excited from the resting position. With any normal length arm ( approx 8 inches or more ) , the seesaw frequency will be around 1-2 Hz - which is WAY below the fundamental system resonance of around 10 Hz. That means any record warps  below 10 Hz must be dealt with exclusively by the stylus suspension - as the cart/arm can no longer follow these. Vestigal or Versa - with a LIGHT cartridge (say up to 3 g, plastic hardware used to screw the thing together ) with enough compliance to allow for fundamental 10Hz (or lower ) resonance will be completely devoid of "woofer dance" ; when I first measured Versa + Ortofon OM Super ( any decent stylus from the series will do, I used OM20), I could not believe my eyes - for the first time, the output of the turntable looked like the output from the signal generator. No aberrations typical for conventional cart/tonearm combos - whatsoever. Substituting Ortofon OM20 (almost bottom of the line, extremely light high compliance cart ) for MC-7500 (then top of the line, but heavy and low compliance cart ) had so devastatingly negative results I really felt sorry for the friend - it would put me, as it did him, on the brink of open crying.
    For those not familiar with either Vestigal or Versa - both would only work properly with a totally flat record. That*s WHY I called the Versa "finally well made Vestigal" - as Versa is a TURNTABLE SYSTEM ( TT + arm), neither of which is (or should be/have been ) available separately. The key element and fundamental condition that has to be met is record flatness - as low effective lengths like these two ( LESS than a typical IEC/SME headshell ) create far too high error in VTA over warps of normal records. It can also be heard as "wow" - dullness as the cart/arm is lifted from "flat" to "peak", then sharpness when it descends from the "peak" back down to flat.  Versa incorporates vacuum record suction system - and logic built into the electronics of the turntable prevents rotation of the turntable itself unless the satisfactory vacuum seal has been achieved in the first place. All that remains of the vertical motion of the stylus/cartridge/arm (besides modulation of the grove, of course ) is the discrepancy of the thickness of the vinyl record(s) itself - but that is inherent flaw of any real pressed vinyl record copy.
    I can not afford the Versa - but have been able to reproduce almost the same result using (heavily modified) Vestigal/low mass high compliance cart with vacuum suction systems on various turntables.
  3. snapontom
    Well, bebophead some of my best purchases did not include an exterior ring, though I thought about it long and hard.  I, I want to make a record change FaST!!!!!  I never return albums my shaved Shibata stylus tracks lower than almost all scratches, excepting my Rolling Stones AFTERMATH London album scratched to bloody hell. The track Paint It Black has never sounded so scratched and spit upon.  My copy is a true classic, played often in its day by everyone.
  4. shaizada
  5. bbophead
    Don't know nothin' 'bout no exterior ring.
    I have a Shibata as well, 2M Black, and, mostly, things are quiet, except for the noisy ones. [​IMG]
  6. Krutsch
    Wow! An amazing collection.
    I need a new turntable ... one that looks like it does dual duty as a time machine [​IMG]
  7. spookygonk
    ^^^ Jesus, that's horrible, something you'd expect Prince to own (though I doubt he would have gone for something that gaudy).
    (also RIP Prince)
  8. shaizada
    LOL! Doubt is a disease...it infects the mind.
  9. mulveling Contributor
    I rather like the purple. Very bold; a conversation starter for sure -- you get a nice lady in your place and you're gonna have something to talk about! The arm situation looks a bit crazy though. As with human beings, 2 arms is good...3 is cause for concern.
  10. shaizada
    The table actually is setup for 2 arms with 2 matching purple pods.  I have a Schroder Reference arm in a separate arm pod that I might use as a third arm.  It all balances visually as 4 pods around the turntable.  The DC motor can also be thought of as a pod in a way.
  11. PATB Contributor
    Here's an iPhone pic of my Ace Spacedeck
  12. Packgrog
    My new addition, more forum-appropriate than most:
    Anavel0 likes this.
  13. floydfan33
    Rega RP3 White with Pure Fidelity RP6 Delrin Black Platter and Pure Fidelity RP6 Subplatter. Just the Elys II for now but looking at upgrading soon.
  14. bbophead
    Aww, NICE!
    I'm such a Rega FanMan.
    I didn't know Groovetracer had a competitor in Pure Fidelity.  I'll have to check them out.
    I enjoy the 2M Black with my RP6.
    Congrats!
    Is there a Pure Fidelity website?
  15. floydfan33
    I purchased through Canuck Audio Mart. They are based in Vancouver, BC and great to deal with. Link to their page there:
    http://www.canuckaudiomart.com/userprofile.php?user_id=100917
    Really well priced. I actually purchased the platter, subplatter, insert, ruby bearing and belts. Very quiet and they look great.
