I'm really tempted to get the XDP David... But I keep hearing others say they have to use an external amp which is ridiculous at the price point. I can't see myself walking around with an external amp using the XDP
Well, I you get a EU version yes the X7 is more powerful (100mW vs 75mW) and FiiO doesn't seem to respect EU regulations as much as Pioneer does. Keep in mind though that the 6dB attenuation will apply with KitKat with 3rd party app, something the Pioneer doesn't suffer from.
I can attest to that now that I have the JP DP-X1, single ended it's rated same as XDP-100 and I am running volume much lower for same output (90/100 out of 160 on normal gain vs 120/130 on high gain with EU version).
Oh, you cynic. I actually had lunch and some beers with the What HiFi guys after a Reader Blind Listening test event. I couldn't help putting this very point to them that it's a widespread view. They seemed genuine denying it, but then you could say they would, wouldn't they!
Ok, I've loaded my 128 gig card with music but I'm finding that the music doesn't show up in the music folder the first time I open it. I usually get a message "music is not working, do you want to close it" or something similar. After closing and reopening then my music shows up. Anyone familiar with this issue?
I will be getting my xdp 100r on tueday. It will be nice to have 2 micro sd slots. One for my hi res music and one for my itunes library. Unless there is a glaring issue, or a difference in sound quality, which i doubt I will be able to hear. I will be sending the x7 back
is there a way to get just the folders to show. The dap has a million ways of showing the music but ai just want to see what's in the folders themselves. Hopefully this can be a future fix.
also, did anyones iTunes playlists show up after synchronizing sd card after copying? I need playlists or just the folders to show up. Also Every other way of showing the music still lumps each album separately.
hI made a duplicate iTunes library of my music, then I took all songs for each playlist, renumbered them based on playlist number. So basically, my folders are playlist and not folders of albums. I thought, now I can just copy these folders and just view folders and I would be viewing my playlist. This didn't work on the Pioneer.
I just dragged my iTunes folder onto the sd1 card. All my music showed up but no playlists. I have been working on an alternate iTunes library of my music where the folders themselves are the playlist. I renumbered all songs in the folder (playlist) numerically to keep playlist order. If there is a way to just see folders on the dap, I would see my folders as my playlists. It's frustrating, all the ways to view your music but none of them being the one you want.
