warrior05
- Mar 16, 2006
i'm not saying that this pink noise burn-in works for all cans and IEMs but i can tell you it made quite a difference with my CX300s.
Originally Posted by hilikus /img/forum/go_quote.gif Here is 5min of pink noise I generated. Just set it on repeat ![]() FLAC (23.5MB ziped) http://mmcgrew.net/media/audio/pink_...noise_FLAC.zip MP3 320kbps (10.2MB ziped) http://mmcgrew.net/media/audio/pink_..._noise_MP3.zip WAV 16BIT PCM (24.9 ziped) http://mmcgrew.net/media/audio/pink_...WAV_16_PCM.zip happy burning-in |
Originally Posted by Akathriel /img/forum/go_quote.gif The shures are all balanced armatured designs rather than dynamic. This is probably why you didn't notice a break in effect. |
Originally Posted by M0T0XGUY /img/forum/go_quote.gif Does it matter the quality of the pink noise? For example, would a lossless version of pink noise burn in headphones better than a lower quality compression? The sample sounds like it was less than 128kps MP3.... EDIT: Forget that website, I'm not paying 5 bucks for 15 minutes of pink noise. |
Originally Posted by dali71 /img/forum/go_quote.gif My new DT880s should be delivered tomorrow; can anyone recommend a suitable amount of time for burning them in? This pink noise seems to accelerate the process considerably, so any suggestions would be appreciated. |
Originally Posted by blent /img/forum/go_quote.gif I was wondering the same thing for my 701s and for when my new 650s arrive? I tried it the other day on the 701s for 4 hours and I believe it may have made a differance. Have to listen more to really tell though. How many hours are we looking at here? |
Originally Posted by jirams /img/forum/go_quote.gif If you have a sound meter then it can be used to set the volume heard in the phones to 90db when using Pink Noise to burn in. This not an excessive level for this purpose. By the same token Pink Noise must be useful as a signal source for amp burn in also. |
Originally Posted by 3X0 /img/forum/go_quote.gif The E2c's are dynamic. They're basically your typical earbuds with sleeves, and in IEM form. That's why they're so bulky in comparison to the rest. |
Originally Posted by mkg12 /img/forum/go_quote.gif Anyone familiar with any cheaper decent quality sound meters? |
