Pink noise works wonders for burning-in!
Jan 8, 2007 at 1:44 AM Post #31 of 382
Yes, that is transcoding. I will up a WAV version in a few min.
Jan 8, 2007 at 1:46 AM Post #32 of 382
Since when do you lose info transcoding between lossless formats?
Jan 8, 2007 at 1:50 AM Post #34 of 382
Yes, I was mistaken :-X
Jan 8, 2007 at 2:02 AM Post #37 of 382
Thanks.. I'm getting tons of new gear in the next 5 or so days (AlienDAC, E500s, 3.5 to RCA, Cardas HPI, Recable cable..) I'll set up that FLAC to repeat in Foobar and burn em in all together.
Jan 8, 2007 at 2:03 AM Post #38 of 382
Thanks for the pink noise. My Beyers still only have ~100 hours on them, it might do some good.
Jan 8, 2007 at 2:05 AM Post #39 of 382
hilikus,
thanks for putting up the files.
what volume should I run them on?
Thanks.
Jan 8, 2007 at 2:07 AM Post #40 of 382
Run them soft if your equipment's straight out of the box, a little bit higher than normal listening level otherwise. I think that's the norm.
Jan 8, 2007 at 2:12 AM Post #41 of 382
Jan 8, 2007 at 2:19 AM Post #42 of 382
Originally Posted by SptsNaz /img/forum/go_quote.gif
Thanks,
For some reason I'm only getting it on one channel though
EDIT: Weird, through my H120 I only get it in the left channel but both on my pc speakers...
The balance was in the center on the program when I made it.
Jan 8, 2007 at 2:21 AM Post #43 of 382
Yeh, noticed that. Not sure what's going on, all my music works fine on my mp3 player but this doesn't. My fault not yours
Jan 8, 2007 at 2:23 AM Post #44 of 382
Hmm maybe just use it off of your computer.
