Wyd4
Yea true, Poweramp works well on android, Can always tweak the eq and bass treble to suit the song.
Do you use the foam or the rubber buds, because I have heard the silicone buds give them more bass
but sound cancelling becomes worse. I havn't bothered changing them yet.
To be honest I only used the foams with them when I had them.
In saying that, the foams have a rubber inner so I would imagine the difference wouldn't be as great as some foams to silicone.
From my experience with my um mentors, the foams gave the impression of more bass (due to seal and isolation) and less detail in the upper range (either less detail or less perceived detail due to the increase in lows).
With those I actually preferred silicone as they were a very thick sounding iem through the mids so I found the silicone kept everything a bit lighter and detailed.
Really you just need to play around. So many factors come into play.
Seal, small bore, large bore, insertion depth, foam etc.
