Aug 8, 2023 at 9:55 PM Post #36,436 of 38,948
The ISN GC4 Cable and Penon Volt.
Aug 9, 2023 at 10:28 AM Post #36,440 of 38,948
These babies arrived yesterday... The Fiio FF3 is a fantastic earbud... my second bud and favorite :)
Also finally managed to convert a part of my FLAC library to ALAC (48/16) to have the 5th gen iPod work fine without stuttering (using Rockbox) .
Aug 10, 2023 at 7:41 AM Post #36,443 of 38,948
How do you like the DX170?
Regarding sound, I really like it, it's really close to my previous DX300 (not in power, but in tonality and technicalities).
Regarding its size, it is ideal. It allows for easy handling, yet is still small enough to easily carry with you.
Regarding its operation, it is its weak point. It would really need a more powerful CPU to run faster. Everything runs a bit slow, at least at first, until you get used to it.
Aug 12, 2023 at 9:25 PM Post #36,446 of 38,948
Sony WM1A with MrWalkmans firmware/Kiwi ears Quintet/ISN CS02 cable........synergy!
Aug 13, 2023 at 3:39 AM Post #36,447 of 38,948
Sony WM1A with MrWalkmans firmware/Kiwi ears Quintet/ISN CS02 cable........synergy!DSC_0250.jpegsa.jpeg
Funny ... as I was just playing with nearly the same combo these last days.. I just found that using the AZLA SednaEarfit Max for TWS was the best option for me..
I really enjoy the low profile form factor of the Quintet which is nearly better then the already very good IER-M9 => so thanks to the special 3D printing type which offers a kind of perfectly ergonomic shape for my ears, though the nozzle is rather deap and thick. (At least, the Quintet is like a rather good option for side sleepers to wear them for 6 to 8 hours without hurting the inside ears).
Actually, I am still in a brain burning period for Quintet's sound quality... I think, at this time, I still prefer the IER-M9's timbre and even mid high/high frequencies.
But, it's possible that, in a few weeks, the Quintet will become my favourite IEM over all others, this can be due to the low profile with a perfect ear fit and a very enjoyable sound quality.. over IER-Z1R, EXT, IE 900, IER-M9, XBA-N3AP, IE600, FW1800, WU Zetian ... I am impressed the result of such 270€ IEM which can offer such benefit.
Aug 13, 2023 at 3:45 AM Post #36,448 of 38,948
@newworld666
I know, I know, the Quintet really starts to grow on you. It gets under your skin and doesn’t stop getting better and better. My ISN CS02 cable in 4.4mm with the Sony WM1A (with MrWalkman’s firmware) is working miracles. I don’t know if you have heard the ISN CS02, but it takes that treble shelf the Quintet has and it polishes it up and somehow gives it a unique personality, different than I have ever heard it? Wild, as it will remain as my cable due to that quality, and the fact that it boosts the bass? Any CD quality the Quintet had was replaced with analog?
Aug 13, 2023 at 6:25 AM Post #36,449 of 38,948
radio ronja 77.7fm returns...
astell & kern kann alpha > dbl stakked with > oriolus BA300 tube amp > pioneer se monitor 5 as per usual
