Jul 30, 2019 at 5:28 PM Post #28,156 of 38,937
They are much lower in price in the UK now. What sort of eq options does it have?
The eq is ok but its wheel and screen were horrible. I used it mostly indoors.
Jul 30, 2019 at 5:38 PM Post #28,157 of 38,937
And kind of have that Iron Man theme going on:beerchug:
I'm hard pressed to believe this is a budget rig! Then again maybe not as Sony does make one of the nicest DAP's on the market:rolling_eyes: These MH755's could very well be the best bang for the buck iem on the planet (of course one really needs to put even length cables on them):wink:
Is that a Colorfly C3 with a Topping NX1s underneath it? Do the Sony's need an amp?
Jul 30, 2019 at 5:48 PM Post #28,159 of 38,937
Cayin N6ii and Sony IER Z1R
Jul 30, 2019 at 6:16 PM Post #28,160 of 38,937
Trick case and nice control cut out however I believe you've voided your kayak/water sports mode:rolling_eyes: I use my Nanuk with BT DAP's & Waterproff BT speakers during water activities but I do love that clear Pelican and how you can see the MO screen and Mojo lights:grin:
Thanks! I seriously considered going full-on waterproof but this was much simpler.
Jul 30, 2019 at 8:33 PM Post #28,161 of 38,937
Not really but all Sony’s have needed more juice than most at least for me but like home speakers more power is always better. I use the C3 combo with my cans (AKG553’s & Senn HD6XX) more than iem's:beerchug:
Jul 30, 2019 at 8:44 PM Post #28,162 of 38,937
Ah, that looks nice and clean. What for is the small/thin cable of the Sony DAP?
It's for grounding because Sony didn't ground their 4.4mm connection.
Jul 30, 2019 at 9:19 PM Post #28,164 of 38,937
Im sorry, but that's too funny. Sony didn't ground their much-touted, superior balanced output on their $3k flagship dap??? Just wow.
That's what I've been told :(
Jul 30, 2019 at 9:57 PM Post #28,165 of 38,937
Recently acquired the Msr7b. Also use the 99 Classics and Beoplay H6 with either my V40 or Opus#1s. Been listening to the Highway to Hell album a lot this month, to celebrate Bon's birthday, and the 40 year anniversary of the album.
Jul 31, 2019 at 4:02 AM Post #28,166 of 38,937
I'm not 100% sure how you mean it with grounding, but I think that nobody is using grounded pin on 4.4mm connector for headphoens. Similarly 2.5mm connector also has no grounding pin.
For example here is pinout on 4.4mm adapter from Cayin
Adapters from MEE Audio
Jul 31, 2019 at 4:16 AM Post #28,167 of 38,937
I'm not 100% sure how you mean it with grounding, but I think that nobody is using grounded pin on 4.4mm connector. Similarly 2.5mm connector also has no grounding pin.
I believe that Han Sound Audio is one of the few that uses it for their Venom cable when it is terminated in 4.4mm. But that one also comes with a parallel 3.5mm (SE) plug for the ground in case the cable is terminated in 2.5mm (ie. the cable has 2 plugs). Of course the 4.4mm terminated cable will only work on a modded WM1Z (or other 4.4mm DAP).
Jul 31, 2019 at 10:38 AM Post #28,169 of 38,937
Oriolus offers the PW Audio 4.4 + 3.5 interconnect with their balanced tube amp.
