- Thread starter RingingEars
WM1A > ToneKing 8-braid SPC balanced 4.4mm > FiiO FH1 Blue
psikey
- Jul 15, 2008
silvahr
https://www.amazon.com/dp/B01N3AZPK...coliid=I1G0X7Y2IF6L7U&colid=RD1WMYV4FYK5&th=1
You can also buy the cradle, this will charge your player and have digital out, I want to buy this for my 2 channel system but the price skyrocket this month before it was around $125. when the price drop I will
https://www.amazon.com/dp/B00S94R5RK/_encoding=UTF8?coliid=I142C7KWSLVMH&colid=RD1WMYV4FYK5&psc=0
Can you please tell me if using the cable to connect WM1A to H2 will drain the WM1A battery?
Thank you in advance!
kel77
- Nov 16, 2015
Sp1000cu > cdm > xelento
Yes it will but shouldn't be a problem, the WM1A have good battery life. We all have different listening habits, if your low on battery and you listen to your headphoneCan you please tell me if using the cable to connect WM1A to H2 will drain the WM1A battery?
for 2 hours before you go to sleep then you should be good. On a full battery i say 15 hours
So mean, those headphone look comfortable, sometime I don't want a big iem with 10 driver in my ears.
TheGame21x
Devodonaldson
Detailed thoughts on the Saba Da3, if you don't mind. Can't find a decent review anywhere. Currently using a Dragonfly red. Would be partnering with a warm portable amp, so power output isn't a big deal.
Dude it’s just a bit of fun, I have even done that myself a few times. Everyone is so serious...
snapple10
helping getting the work done rig
- Oct 2, 2015
Going back to my first iems when i ventured into this hobby.
TheGame21x
It's an excellent performer for the price. Actually, scratch that, it's an excellent performer, period. In both desktop (as a standalone DAC feeding a more powerful amp) and portable (like my picture or with a laptop) settings, I found it to be a transparent, detailed and resolving little amp/DAC. It doesn't have a ton of output power, even if you opt to use the 2.5mm balanced port but for low impedance, high sensitivity loads like the Massdrop Plus IEM I have pictured there, it's a satisfyingly powerful setup that sounds great. It's a nice, solid feeling little device that's a great performer, no matter what I've thrown at it so I'm very pleased with it for the $96 or so I spent on Amazon.
Redcarmoose
Total: 25 (members: 9, guests: 16)
