- Jun 3, 2014
Which spinfit tips are those? the stock tips on the s-em9 aren't ideal for me. Also let me know if you find that 1plus2.2 alternative, i've been tempted but it seems Gavin has limited involvement now.
These are the narrow bores, the cp800, work perfectly, but the stem has to be clean otherwise they will slide off.Which spinfit tips are those? the stock tips on the s-em9 aren't ideal for me. Also let me know if you find that 1plus2.2 alternative, i've been tempted but it seems Gavin has limited involvement now.
This is head-fi, play back is more important. In here we dim the screen the screen to the lowest and try to use the side button more then the screenYeah, was a little disappointed the kann used such a crude display.
I hear you on the amoled burn in - also, the RG deteriorates at a faster rate than B in general so given long enough (and not burned in) everything will be blue shifted from what I've read.
But the inky deep true blacks, and the awesome viewing angles..
My end game portable (minus an upgrade cable at some point in the distant future)
Ak70>8.2 Harmony
That's the illest looking (actually) portable setup I've ever seen.
I've also been rocking my AK70 (same color) naked 24/7, great aesthetics. I didn't like how the case covers the buttons, made it hard to feel for the play/pause with the unit in pocket.
Thanks! Yeah, I wanted something that would actually fit in my pocket lol. Plus when I'm on the go, small fidelity changes ala portable amps/dacs/daps/cables don't really matter. I'll do critical listening when I'm back to my desktop rig
Edit: And I agree, the AK70 is gorgeous. Am I the only one that only buys gear that I think looks good? XD
The Sony's and some Sriracha Hot Chili Sauce and you look all set.....Sony WH-1000XM2 used with an iPhone 8 Plus
Happy Holidays portable lovers!
Hi Pinky -
Is that the iBasso? How does it compare to your Cayin?
Been researching DAPs with offline Tidal and these came into my sights (along with the X5iii, X7ii), your impressions will be much appreciated and valued.
Thanks x
Did you compare both SP1000 before going for copper?
CustomArt Fibae3 - Ares ll+
