Jan 20, 2011 at 6:33 PM Post #2,118 of 3,208
The PortaPros respond very nicely to being EQ'd. They do not lack bass at all. Listen to Smooth Criminal, particularly the first part with the heart-beat.
I've just discovered the KSC-75 : the Portapro is reported the same headphone with a proper headband to clamp the earcups onto your head and give you improved bass response. I would defy anyone other than the most ardent headbanger to describe the sound that comes out of these things as 'bass shy' : if anything, I have to wonder whether I could handle several hours with the drivers clamped tightly to my ears.
Jan 20, 2011 at 10:54 PM Post #2,120 of 3,208
I have both. The KSC75 has a titanium coated driver and has more treble/PRaT and airier sound (which is not just a product of placement. The drivers of the Porta and KSC75 are interchangeable.)
I really need to post pics. I probably will when my N2 comes in. Got a lot of nice goodies to show off.
Jan 21, 2011 at 5:52 AM Post #2,123 of 3,208
Do you mean album art? If so, then it is the cover for the album called Metallica (otherwise known as the Black Album).
No I meant behind the album art...the grey and all.
It's just the standard background taken in the black and white settings on my camera. I'm not using any wallpaper or UCI. I used to use multiple UCIs, but I screwed up a setting in Claw and had to remove it. Ever since then I haven't really found the time to experiment with other UCIs.
Jan 21, 2011 at 5:56 AM Post #2,124 of 3,208
It's just the standard background (for 2.53) taken in the black and white settings on my camera. I'm not using any wallpaper or UCI. I used to use multiple UCIs, but I screwed up a setting in Claw and had to remove it. Ever since then I haven't really found the time to experiment with other UCIs.
I actually found them quite comfortable. They don't cling to hard on my head, which I'd say is average-sized. If you have a large head I can see if it would be a problem considering the headband doesn't extend all too long. Another track to really enjoy the PortaPros with is "God of War 3: Overture".  It was like listening to a whole new track when compared to the iM-590.
Jan 21, 2011 at 6:03 AM Post #2,125 of 3,208
I've had them on for a couple of hours now, and they seem comfortable enough to me. Of course, I keep my hair buzzed, so the legendary hair pulling isn't an issue for me.
Jan 21, 2011 at 1:00 PM Post #2,126 of 3,208
Gotcha.
Jan 21, 2011 at 7:33 PM Post #2,128 of 3,208
I just got the KSC75s the other day, and love them. I use my Iriver H120 which outputs a lot of power and has Rockbox, and usually put the bass to +10 or +20, depending on what I am listening to. I modded them by cutting holes in the earpads and putting another set of earpads I had over that. They sound even better now. There is real bass to them, at least with EQ.
