Well the pico has a pretty good dac section by any standard.
If you want to step up, from what ive read you'll have to spend over 500 bucks to get better sound than the pico.
Don't let the 1/8 connection bother you. It will still transmit a good signal to your amp.
I used a Pico DAC/amp for the DAC only sending the analog signal to a Woo 3. I did this for over a year with no problems. I used low gain at max volume.
. Spent sometime yesterday reading, the Audio-gd D19 DSP1 should be awesome with the WA6. My headphone Denon D7000 should be here Tuesday and will take sometime to decide. Thanks for all the help guys.
