-sandro-
- May 11, 2011
Nobody knows that the 37xx series is? Amazon describes it as the successor of the 35xx but I'm not convinced.
I just received 3 pairs of 3590bk/10's.
Well, definately have to get used to that bass. Overall, pretty sweet.
The plug sits a bit loose in my galaxy s7 and wiggling and turning the plug causes chirks and differences in sq.
And playing with audio effects in google play has much more effect than with any other iem i've used.
I have the idea that these iem's are far from optimized, you could get them to sound much better with a proper eq setup and/or recabling.
Has anyone tweaked these to awesomeness already?
Oval tip not friendly with my ear canal. Any way to remedy this?
isn't that the normal shape of the ear canal? also they're so small...
you're not alone, I also have different fit with the Right side. not with these thoughI'm a bit puzzled with them. It seals too good one side (right) and not left.Even with different tips. I thought maybe it came down to oval. I might have to try some foam ones.
But i really dont want to foam up every iem = $$$ 30 bone foams for 10 bone iems
Sometimes tips can be fussy depending on conditions like ear oils etc.I'm a bit puzzled with them. It seals too good one side (right) and not left.Even with different tips. I thought maybe it came down to oval. I might have to try some foam ones.
Anyone try the SHE4300...https://www.philips.com.au/c-p/SHE4305BL_00/bass-plus-headphones-with-mic
I have the 4205 earbuds and the driver is very, very capable. Not that it translates when turned into an in ear. Not even saying they are the next big thing after 3580 and such but has someone checked to see??
