Jimmy80
- Sep 3, 2014
For hygiene purposes, removable pads allow us to wash them and depending on use, some can worn out very easily but I am not too sure about Philips's pads thought.
Billson
It's just the idea. When you have expensive headphones that have even great construction the earpads are the place where you will expect problems. If you can't take them out you feel like if something ever happen to the earpads it's end of the entire headphone.
I dunno about that Philips HP890 and how much you use them, but I know Sennheiser headphones and Beyer headphones and though their pads are very comfortable they get worn over time very noticeably, the difference between the old pads and brand new ones on the DT770 is huge and same for DT880 and HD650/HD600, not even talking about sound but about comfort.
Okay, thanks. Im using my Philps headphones everyday at work and yes they could use some cleaning but wear is minor.
Here in Sweden the X1 have a regular price on $297,89, there is however some companies that have them for $243,73. Im not really sure if I should wait on the X2 yet. I suspect that the X2 will cost about $338,51 the first 6 month here in Sweden.
I have talked to Philips and they say that the following is changed : Wider range of sound, Change in design, Better qullity leather for headband, replacable ear pads.
I have listen to a lot of headphones around the $67,70 price range and nothing even comes close to the Philips HP890(I supose that its the open characteristics and deep base I like). The Philips HP890 cost me about $60 2002 and its first now when the X1 came out that it looks like I found a replacement. So the "better" sound of X2 will probably make no diffrence for me but replacable pads is as you said a big plus.
Its possible to remove the ear pads on X1 with some work but the question is of the X2 pads will fit?
