Hi, yesterday I finally got The Be´s. Well, right OTTB, I liked the bass presentation, but a little worried as I perceived vocals a bit recessed and with lack of details, and the highs extended without a hint of sibilance or harshness. That was based on a very quick session with R&Bs and contemporary POP music.
Left the BEs playing music overnight at my usual volume levels, and this morning another quick session before going to work, and surprise... Midrange showed more upfront, with lots of details and dynamics, treble doing its thing smoothly.
Ah, the BASS, very detailed, layered, strong kick, and as
@PaganDL mentioned, bass presentation varies depending on the source recording.
So far very very happy with this purchase. I can finally enjoy Depeche Mode´s tracks with such a strong and detailed bass foundation as expressed by the BEs!!
Regarding soundstage, is not huge, no complaints either, but sound image and instrument separation is really great. I have noticed great depths, having sounds extended behind my neck, and that never happened with my DM6, Toneking T4 or Ibasso IT01.
Best of all, BE are not as intolerant to bad/poor recording/mix as with the temperamental T4, nor fatiguing as the DM6 can sometimes be.
I have the feeling BEs will be great for long sessions.
I did a little tip rolling, so far the stock silicone double-flanged tips worked the best for me, and wide-bore being the worst offenders.
Aldo tried some Final E tips, which fits me well with my other IEMs, but no so with BEs, go figure.
The memory foam tips are just a tad too big for my ears, so not a perfect fit, but provided a solid seal and good sound nonetheless.
How long took you guys to have the Berrylium drivers to settle down? I am going to give some more burning time and keep on checking on changes. But right now I think for the price I paid this is a terrific pair of IEMs.
Ah, I hate the cable, so prone to tangle, is thinner than the Final Audio E3000 cable and does not feel as robust.
Not sure if the BEs would be adequate for outdoor use.
Will appreciate your recommendations on tips that work great with BEs, and how to elevate the source performance, maybe going the Nickel route or adding a DAC/Amp as the Topping NX4 to my Cayin N3 DAP, or getting Fiio M11?
Thank you all for your comments, I have the feeling I nailed it with the purchase of the BEs.
I will get my money ready for the time Periodic Audio comes up with a new model with detachable cable!!
cheers, Jose
