jc9394
- Feb 6, 2006
Yikes is correct, my mistake not clarify it. It is double boxed.
All right, thanks for both you Yikes and jc9394.
Yikes (no pun intended), when freight is considered this DAC costs almost as much as 1.5 times of the Audio-gd's Reference 7, another DAC that is in my short list.
Unless a restrained sound and artificial smoothness is your cup of tea, I'd take the Reference 7 off your short list IMO. I heard it compared to an older Theta Gen Va and I greatly preferred the Theta.
btw, how do you guys feel about affordable transports for the pwd?
It's the loaner Ref 7 and I believe it is NOT using the v5 module. I also have a hard time believing that makes much of a difference, but I have not compared the modules.
Believe it. Kingwa himself even said the difference was significant and he never says stuff like that.
But I haven't heard the v4 module that was in there so I don't know how close that one is to v5. I had v2 or v3.
That much more there? Did you checked Audiogon.com? They are a little more than Ref 7 when I brought mine.
With the current PS Audio DAC trade-in program, you should be able to get the PWD for $1999. If you don't have a DAC to trade in, there are authorized vendors that are selling it for substantially less than $2999.
