igor0203
I ordered Sansa Fuse, I hope I'll be satisfied. If not, I'll go in hunt for new.
The Sansa clip is a normal sounding player. It doesn't do anything really wrong, but then again it doesn't do anything exceptionally well. I have a Fuze that is supposed to sound the same and the sound is pretty flat and non dynamic. I have tried other players that sound much better, such as the S:Flo2 and the QLS QA350.
Anythingbutipod.com is a good site, but sometimes I want to start anythingbutsansa.com to counteract their sansa madness. They are irrationally crazy about the clip because it measure flat on some test. Guess what? it sounds flat as well, and not in a good way. The clip has its place as an ultra portable cheap player that sounds decent, but decent is not anywhere near good.
Quote:The Sansa clip is a normal sounding player. It doesn't do anything really wrong, but then again it doesn't do anything exceptionally well. I have a Fuze that is supposed to sound the same and the sound is pretty flat and non dynamic. I have tried other players that sound much better, such as the S:Flo2 and the QLS QA350.
I'm also inclined to agree that both the 5.5G iPod and 3GS especially have far better clarity. The Fuze is quite neutral, but the sound reproduction is relatively mushy. Rockbox only really fixes the sound signature if you don't like flat. You can't fix the lack of clarity though.
Cowon J3
Cowon S9
Iphone 3gs
Clip+/Sansa Fuze
Cowon D2
Iphone 4
Ipod Touch 3g
Ipod Nano 5g
Ipod Classic
Haven't heard cowon 9, 7.
I'm looking for replacement for my iPod Nano gen.1. It's nothing wrong with it it's just that I have huge collection of music in FLAC and don't want to convert all music just that I can play on Nano. Plus it's only 2GB.
So I was looking around and thinking to buy Sansa Fuze/Clip+. Will I downgrade in terms of SQ? I don't want cheap crap player, I want decent sounding one. Or maybe Cube C30/its derivates?
Also is S:Flo2 small enough so that I can take it on jogging?
Source is the most fickle part of an audio rig. There is never 1 source that is good in everything for sure. I know this coz I've had my fair share of DAPs. I can surmise the following:
iPods - they are OK sounding players. The iPod 5G is probably the best sounding one I've heard, plus you can use Rockbox on it. Still, I do find that I need to amp the iPods to get a decent sound.
clip+ - After having only iPods, the clip+ was a big surprise. Much better sound quality from a much smaller player. Unfortunately the poor battery life and small screen and size really killed it for me.
s:flo2 - Bad customer service aside, the s:flo2 sounded excellent. It deserves the praise it gets for its SQ for sure. However for me, SQ isn't everything, and eventually the really bad UI and awkward shape made it a bad package overall.
Fuze - Currently using and so far it's the best. Good battery, easy navigation, Rockbox. Don't underestimate the Rockbox impact. Coupled with the Fuze's amp, it pretty much nullifies the need to use an amp for me. I've tried iBasso D12, P4, D4, Cordas, everything short of RSAs, and find that there is very minimal gain using an amp. I think a lot of people can atest to this, judging by a good number of Fuze rigs here without amps.
So yeah, I don't feel the Sansas are overrated. They are definitely bang for buck, and then some more. Maybe Cowons or the s:flo2 may sound better, but they all have their own problems. After the nightmare that is mp4nation customer service, I'm inclined NOT to spend too much on a source anymore.
