- Jan 30, 2009
^ Nice. You are a funny guy. Thanks for the smile
With JRiver MC19 - I have to change the Output Encoding to "DSD in DoP format (requires DSD capable DAC)"
There's No "Native" option - only DoP for DSD 2.8XXXX
For DSD 5.6XXXX There's two options "Native" and "DoP"
Peace...
DSD files should read DSD 2.8XXXX or DSD 5.6XXXX if set up for native mode
Peace...
Foobar2000 with SACD plugin playing DSD files in native mode without problems
The " Native " option in JRiver MC19 is " None " if you choose DoP then there is a conversion taking place prior to the DSD DAC
FYI... JRiver is now MC20
haha, I honestly think 1 should be enough but again there is no one amp and one dac can do all.
I thought Oppo was good enough to drive HE6 but ffail big time.
I read that as Oppo 1 DAC isn't good enough ? is that why 2 dac chips are required to fill the gap ?
I'm still not getting/understanding the "None" option you suggested...
If I select "None" under Output Format then I'm back to PCM XXX.X/32
In this case PCM 352.8/32 for a .DFF file (1X DSD)
I still have to switch drivers and the Output format to get the HA-1 to readout the correct bit depth...
To play DSD the same is required (switch to ASIO Driver and Output Format Change)...
No Biggie onto Foobar2000 - well maybe tomorrow...
- Peace...
I'm not at home now so couldn't check the settings.
IIRC, there is a setting somewhere which says 'bitstreaming - OFF (recommended)'.
If you changed it to 'bitstreaming - DSD', it will show correctly DSD 5.6XXX...
Medasi... May Lewis Hamilton Win The Singapore GP Come Race Day!!!!
BINGO!
Advice from Knowledgeable people PLEASE!!
Upstairs:
Oppo HA-1.
Denon 5000 with balanced re-cable.
Three Ipod classics.
One Ipod Touch.
Downstairs:
Desktop PC Windows XP containing:
1TB of ALAC music. (mostly 16 bit 44khz CD rip)
55,000 Tracks.
Traditional wireless router for the household.
Itunes 10.7
Android smart phone.
I love the HA-1 amp. That seems to be the consensus of opinion from those that know - i.e here!
Please can you recommend a way for me to dispense with my capacity short (and old!!) ipods and stream wirelessly to the HA-1 upstiars (too far for a cable) with an use interface (on my smartphone?) OTHER THAN SONOS which seems a) Expensive b) isonly 16 bit and therefore not really future proof c) Seems to disappoint some users
I am not a huge techno guy - i renew once every 10 years - just completed - and the technical jargon and three letter abbreviations, and sheer consumer choice is just bewildering. I just want to have availble to choose from - my whole itunes library when I'm upstairs listening to the awesome HA-1.
I'd really appreciate some advice!
Thanks in advance.
