addyg
- Feb 3, 2016
Onkyo - Balanced (silver) - Focal Elear = Sweet treat to your ears. Gratz!
Can you share us a photo?
Thanks, I may check into that in the future but for now I'm just trying to check into why the media volume is sort of determining gain/loudness of the PHA-3..A few notes:
It is connected through OTG micro to micro..
The volume knob on the Onkyo does not operate (as it shouldn't) when running with the PHA-3...Only the media volume plays a part in the PHA-3 volume loudness/gain. If the Onkyo media volume is all the way up and PHA-3 is all the way low, no sound comes out, which is good I guess as I know the Onkyo is not fully controlling the volume..So depending on where I set the media volume, that will determine how loud the volume will on the PHA-3, strange I know...
DP-X1 (without PHA-3) upsamples all flac 44khz to 48khz as shown on the Onkyo screen and specs..Operating with the PHA-3, the Onkyo screen shows at 44khz, which makes sense as PHA-3 does play 44khz..
All in all, I'm just trying to confirm if I'm indeed bypassing the Onkyo's amp/dac and operating the PHA-3's amp/dac..Would love to get some thoughts/feedback..Thanks in advance!!
Actually it is the digital volume of the dac you are controlling. The volume dial is digital. There is an option in Music which gives you control of digital volume.
Thanks for the feedback..I'm not not understanding however, digital volume to what DAC, the PHA-3s..?
The only option on the music app is to disable the Onkyo's ability to use the volum, which in case the Onkyos volume is disabled..but it does not disable Androids Media Volume on the androids settings..
Sure, with pleasure
Go to the Google play store and find onkyo music application. Then update it. Very simple.Can someone help upload the latest v1.71 Music? Many thanks!
Hi Everyone, So I looked all over the web-inets the see whether my X1 firmware is up to date, and I can't find anything. Did Onkyo drop support for the DP-X1? Before I call their 800# I thought I'd ask the experts here first. If you have a link to share I'd really appreciate it.
Thanks for the info KB. Yeah, I've already updated the music App, but I never realized that the firmware updates are OTA.It's OTA update.
If on Wifi you don't have some upgrade proposed by the DAP : you are up-to-date...
PS : and simply go to the Google Playstore to update the Music application.
I saw those updates DB9, but I thought they were meant for the newer X1 DAP's. I'll dig a little deeper and see if they'll work for my 1st generation X1. Thanks for the response.There was at least one update, for the DP-X1B last Summer, and another one, after the DP-X1A was released earlier this year.
My rooted DP-X1B Device Information shows:
Processor info: Qualcomm APQ8074PRO-AB
Android version: 5.1.1
Kernel version: 3.4.0 android-build@DAP #1 Fri Nov 4 01:44:25 CST 2016
Build number: LMY47V
SW version: 0.1.37.8_20161104.013642
